Question about Pool & Spa
Pool Pump Manuals
PE71-II-V
3 Suggested Answers
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
  • 7 Answers
SOURCE: We have a proline above
at home depot the sell a pen that beeps at the sight of voltage (sensor) 12$ good house hold tool to have.. check the cord running to pump see if the pen beeps when held against cord if its a 110 set up the pen beeps and youve the 110 V needed to run the pump if 220 V a bit different .. if left powered But not running in a few min, touch motor housing the metal part of this unit. is it hot as a grill (internal winding problem) or still cool .. Motors are a wear item like tires on ones car.. motors are inexp like 110$ for a 1 hp unit
Posted on Jun 05, 2011
What else could cause power to pool pump to shut off?
Check the timer clock, the timer maybe faulty or the time is incorrect.
Oct 13, 2012 | Hayward 1HP Super Pump II Inground Pool...
We have a proline above ground pool pump. Model PE71 III V. Been working fine the last two weeks. We vaccumed pool and then pump just stopped working. We don't hear any noise....like there is no...
Jun 04, 2011 | Hayward 3/4hp Super Pump Inground Pool...
I have a 1.5hp Proline PE71-11-H Pump. When I turn it on the water comes out of the return in the pool like a rocket but within seconds there is little to no pressure coming out and almost nothing being...
Try to check if the connections were touching. Open the motor then tape the connection to avoid short circuit. Also, you might need to check your wires if they are enough to handle the current. Check the temperature, are the wires getting hot? do you have proper grounding?
Hope this helps.
May 22, 2011 | Pool & Spa
I have a proline above ground poolpump 1.5hp. model pe71-11-h i would like to know if the pump part can be rotated at an 45 degree angle
As long as the vents on the motor are faceing down so no water can get into the elect. you should be fine.
Aug 31, 2010 | Pool & Spa
I have a Hayward max-flo ii pool pump and it is very noisy. I already replaced all seals because it was also leaking. Are the bearings the cause of the noise? If so how do I replace bearings?
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
May 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
May 14, 2010 | Hayward Pool Products Hayward Super II...
Pool & Spa Logo
333 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
