Question about Samsung Colorful Handsfree With Boom Mic. For SGH-p107, SPH-a680, VM-a680 Headset
Samsung sph-a680 phone does not ring
Ok I'm at a loss! My girlfriend has a samsung sph-a680 it has tones when it turns on or off. Also keypad tones but when a phone call comes in it WILL NOT PLAY ANY TONES! every once in a while when a text comes in it will play a the melody (the one she has set for text). Any ideas?
STUMPED
techman
  • 3130 Answers
SOURCE: Samsung SPH-A680
LMAO dont fool around with girl friend while working on your electronics .. Im not sure how to do it but I heard of this before as you have to reset to default settings then start over again.
Posted on Mar 26, 2006
  • 33 Answers
SOURCE: keypad tones Samsung E900i
This is pretty stupid thing about E900 software. First you have to change the theme. Then this option will not be blacked out ;)
Posted on Sep 26, 2007
SOURCE: Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Posted on Jul 11, 2008
SOURCE: My Black Jack II ring tone files are corrupted and will not play
check out this thread. near the bottom is an explanation to reset your phone back to default settings. you will lose all programs d/l so I suggest you sync your phone with your comp to save all your contacts first.
http://forums.wireless.att.com/cng/board/message?board.id=samsung&thread.id=68502
Posted on May 27, 2009
  • 39 Answers
SOURCE: Samsung SPH-i325 Ringing Tone problem
It's possible that there's something wrong with your microphone of phone,just change a new one to try it
Posted on Jul 08, 2010
Vibration works and ringer doesn't problem with samsung sph-m540
If the vibration works the circuit is working OK. All what can be done is to reset the phone , remove battery and reset, check for any corrupt files on the memory card. Now open settings, tones and check the default settings. check tone set and tune selected. Now if there is no result the ringer might be open and faulty. You can check the continuity to confirm , if so replace.
Sep 27, 2011 | Samsung SPH-a460
Jul 08, 2010 | Samsung Ace SPH-i325
My phone won't call voicemail
you can try entering ur number plus area code thats works with most phones
Feb 04, 2010 | LG Vu Cellular Phone
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
Turning the key sounds off Samsung A412
Customize profile Silent : select ring tone which ever you want and select Volume and activate the profile
then check keypad sounds or coming or not.
Regards,
Suraj
Feb 19, 2009 | Samsung SGH-d407 Cellular Phone
Can't bluethooth to other phones
You want to send any phone.
For there the another phone blue tooth should be turn on. It should me in visible form and have a name.
you can see these sitting in blue tooth sitting. When it is OK then Go to your ring tone and go to more option while the desire ring tone is selected. After clicking more option a menu will appear in which send option you can see select it and another sub menu will appears select Via Blue tooth.
Then your phone will start searching automatically for other devices and a name will appear of the another phone you will select it and sending will start.
The another phone will must accept the desire file to download.
I hope this will help you.
If you have any problem regards this then please reply to this thread I will explain further.
Thanks
Nov 20, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Samsung sgh - u600 mobile keypad tone wont change
samsun 3500 do not have a keypad tone and when i try putting volume it tells me exit silent mode i am not in silent mode and my phone does not ring either
Oct 21, 2008 | Samsung SGH-U600
Just got a Samsung g600, Under settingd I dont have 'sound settings' as with previous samsung fone. This means that I cannot assign a ring tone for text messages I cant find any way to do this. I also...
Hi, for anyone still having this problem with the newer Samsung phones, I just solved the issue I posted up earlier.
To disable keypad tones, but keep your ringtone etc active, go to Profiles -> edit your 'Normal' profile.
Press right on the selection pad twice to get to phone-related settings. Scroll down to the bottom of that page of settings to the 'Phone sound volume' option, select it and adjust it to zero.
This will turn off all keypad noises and other irritating beeps while not actually turning your phone on to 'silent mode', which would disable your ringtone etc.
Hope this helps, I know I was going insane with this phone until I figured out how to turn those sounds off.
Jul 23, 2008 | Samsung Cell Phones
Samsumg C300
ok... your keypad flex might get loose or dirty keypad contacts inside or check your volume if it get stuck... or
if you can open your phone, checks its connection or keypads contacts get dirty...
hope that solves your prob...
Oct 29, 2007 | Samsung SPH-i500 Handheld
Samsung SPH-A680
Mar 25, 2006 | Samsung Colorful Handsfree With Boom Mic....
Radio Communications Logo
52 people viewed this question
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
