Question about Mitsubishi WS-65807 65" Rear Projection Television
Channel info pixilated, distorted, HD works intermittently
I've had my Mits for about four years and recently the channel information is distorted to the point that it can not be read. Any suggestions on the cause? Also, recently when I attempt to switch to HD, the set acts like it doesn't have an input. I've verified that the signal is entering the set but the set doesn't find HD or digital signals. Thanks for any assistance
  • Anonymous Mar 30, 2014
    picture pixilating occasionally on bbc hd channels and quite a lot on itv channels.this has only started recently.
    Genius:
  • 1,694 Answers
2HDW sister PCB most likely suspect,if source(s) are ok.
Posted on Oct 04, 2007
My 787 receiver is 10 years old. It worked excellent all these years . It developed distorted sound in the front left channel. I swapped speakers and confirmed that the problem is with the receiver front...
The problem will be in the power amp for the the left channel. One you have identified this on the circuit board you can compare the channel with the right. As they are both the same. Start with a visual check. If anything looks odd compared with the the right replace it. Distortions are often caused by a burned resistor. Though the main power transistors or IC can cause it too. If you can't find anything visual I would replace the main output device(s) for the left channel.
Nov 21, 2017 | Audio Players & Recorders
Re, all i get is a distorted picture of the game screen. I've tried fine tuning the TV around that channel but it doesn't help.
hi sounds like the av sender inside the ps could be getting dodgy, have you tried it on another tv?
Apr 07, 2012 | Sony PlayStation (PS) Console
We have a 4 year old Visio HD TV. Recently we had time when both the HD channels and going up and down using the channel surf buttons did not work. The low Def channels would work and entering the channel...
I don't believe that it is cost effective. BUT, if you have Comcast, you will now need a cable box to watch most channels now. I believe they stop at about channel 12 without the box. It's their way to stop cable thieves, but it's an inconvenience for the rest of us.
If this isn't the case, you might want to try to contact Vizio tech support www.vizio.com. or try to reset the TV - unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if it helped.
Apr 22, 2011 | Televison & Video
I'm new to the HD world...just purchased a LG 42LH40 a couple days ago...and have a couple questions to make sure my TV is operating right. 1) When watching an HD channel (CBS for instance) there is about...
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Jan 09, 2010 | LG 42LH40 LCD TV
Pixilization on non hd channels with hdmi cable connected to HDPVR receive. HD channels come in crystal clear, non hd channels are all bitmapped and horrible
Your TV is not at fault, it is showing you the difference between HD and non HD channels. HD TV's work great with HD scorces but don't usually look that great with standard definition, Also the non-HD channels are more likely to be heavily compressed which makes them look bad too.
Nov 03, 2009 | LG 42LG30 42 in. LCD HDTV
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Speaker distortion when amp is on for a couple of hours
Check out the Bias resistors in the that channel then compare with the right. You might need an Ohm meter to do it, but the resistor(s) could look burned.
Mar 25, 2009 | JVC Audio Players & Recorders
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
Channel cuts out
I suggest you switch your speakers and test again , if the same happens , ship it it can only be an output problem >>>>Good luck
Jan 30, 2007 | Classe CAV-500 5-Channel Amplifier
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
