Question about MSI Computers & Internet
Can't find connectors for internal speaker on MSI Motherboard K9A6M3
Can't find where to connect plug for the internal speaker (the one that beeps) no mention of it in manual.
  • 807 Answers
It should be something like this, look at the bottom edge.
Posted on Feb 22, 2012
5 Suggested Answers
  • 16 Answers
SOURCE: help with hook up audio connections for MSI PM8M-V MOTHERBOARD
http://eu.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=205
pick one of the manual downloads at the bottom of the page :)
Posted on Jul 03, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: constant buzz after beep...
Hello
These are sound codes or beep codes.Usually one long steady beep is a problem with your memory or cpu is not onstalled correctly
Posted on Apr 21, 2010
  • 78 Answers
SOURCE: Where do you connect External Speaker to motherboard
Hi
I am providing you with some links one has details of connecting internal speaker to the motherboard, other has complete product guide.
Following link is for complete Product Guide http://downloadmirror.intel.com/15630/eng/DG35EC_ProductGuide01_English.pdf
If you want to connect external speakers you may connect them by plugging the green connetor of the speakers to the green jack / slot which is at the rear / front end of the system. Just look of Green female slot on the system.
On the left side column, where you see Bookmarks, Select Installing and Replacing Desktop Board Components then select Connecting to the Onboard Audio Systems.
You will complete details here on this link.
Regards :)
Posted on Apr 26, 2010
damnor01
  • 1179 Answers
SOURCE: P5KPL-AM speaker beep
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sadael.
Yes some-times the case/computer chassis does not have an internal BIOS/CMOS beep code speaker built in.
So what you will need to do is go to your local computer store and purchase a mainboard beep code speaker. You may even find it online at your favorite computer store.
The modern speaker is very small compared to the older mainboard beep code speakers.
Your computer will continue to work without the speaker, the beep code speaker is there to help diagnose/troubleshoot problems when they occur.
Take care!
Posted on Dec 16, 2011
Main Speakers Loose Contact
pls. take out your speaker wires and cover the leads with soldering lead and connect it back.
Mar 16, 2013 | Audio Players & Recorders
How to & where to connect Power led + - /power sw/reset sw/HDD led
Get the user manual here: User Guide
Chapter 2 Page 17.
The plugs just fit on to little pins in the bottom corner of the board.
If you connect them and hard drive indicator light on the front of the case does not come on then you need to swap the 2 connectors around.
It's an led which has to be connected the correct way to work.
Same goes for the power led on the front of the case.
Jan 26, 2012 | MSI MS-6378 Motherboard
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
moz-screenshot.pngmoz-screenshot-1.pngYour front panel audio / microphone connector has an AC97 connector inside which looks like this:
http://www.digitaldingus.com/reviews/silverstone/fp34/fp34-usb-ac97.jpg
It is probably plugged into the motherboard somewhere. Try plugging it into the soundcard directly if it is in the motherboard. Or vice versa if it is plugged into the soundcard.
-Alex
May 06, 2011 | Computers & Internet
I NEED DRAWING FOR THE FRONT PANEL CONNECTION
Download the manual for you're MSI PM8M-V motherboard from MSI; http://www.msi.com/index.php?func=searchresult&keywords=PM8M-V&table=download
You will need to download and install Adobe reader to view the manual. Download Adobe; http://www.adobe.com/products/reader/
Open manual to page 9. See Front Panel Connectors: JFP1 & JFP2. There is no need to connect JFP2's Power LED jumper, this is completed at JFP1. Each wire jumper coming from the case will have one wire color in common with all connectors except the speaker jumper. That common colored wire will be use as negative.
The speaker wire commonly as red is positive and black is negative.
Cheers'
Mike
Apr 22, 2010 | MSI PM8M-V Motherboard
Connection of inbuolt speakers on motherboard..
Dear User,
Pl Take Your Motherboard Make and model no with its diagram.
(1) Diagram contains inbuilt speaker pin where to connect wire.
(2) Anoter way please see on your motherboard small pin when wire hang. Read Carefully around pin in small latters for speakers pin.
Feb 26, 2010 | MSI K9MM-V Motherboard
Connectors
i think this is enough which is given on the msi site itself contains all info about the connectors
http://msi.com/index.php?func=proddesc&maincat_no=1&prod_no=1438
download manual from this link
Jul 04, 2009 | Intel Motherboard
Connecting the mic
Download the manual from the MSI motherboard sitehttp://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=487
exists in 6 languages, and it is explained very well...if you need more help, you welcome.
Nov 26, 2008 | MSI 845E Max2 LR Motherboard
Need to know where the black yellow speaker wire gets plugged into a msi k9a2 platinum
Audio Ports
These audio connectors are used for audio devices. You can differentiate the color
of the audio jacks for different audio sound effects.
Line-In (Blue) - Line In, is used for external CD player, tapeplayer or other
audio devices.
Line-Out (Green) - Line Out, is a connector for speakers or headphones.
Mic (Pink) - Mic, is a connector for microphones.
RS-Out (Black) - Rear-Surround Out in 4/ 5.1/ 7.1 channel mode.
CS-Out (Orange or Yellow) - Center/ Subwoofer Out in 5.1/ 7.1 channel mode.
SS-Out (Gray) - Side-Surround Out 7.1 channel mode.
Apr 23, 2008 | Intel Motherboard
Computers & Internet Logo
566 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
