Question about Hoover Washing Machines
The machine blocked and the door security, tumble dryer, and the 3H leds are blinking. what can i do?
The washing machine suddenly stopped. the door remains blocked. the security door led is blinking as well as the spin speed led and the 3h led. can you suggest anything that I can do, please? thank you very much.
    Problem Solver:
  • 9 Answers
Your wash load may be unevenly distributed in the drum. To unlock the lid, try unplugging the machine & plugging it back in after a few minutes. Redistribute the clothes in the washer & try it again.
Was this a washer or dryer problem? The answer should probably work for both.
Posted on Feb 21, 2012
3 Suggested Answers
FAV6800AWDIY
  • 526 Answers
SOURCE: I dont have a manual for my maytag neptune TL and
Hi Denice'
I have never used the delay function. I'm not even sure how to access I just fix broke FAV6800A/FAV9800A machines.
Look like this;
Here is the Service Manual see the Use and Care section in the back of the SM page 63 looks like they discuss the delay function.
I hope this will help you........Rich
Posted on May 18, 2010
  • 6277 Answers
SOURCE: awg5122 not draining light over
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 05, 2011
How do I replace the door switch
Go to espare.com and watch the vidios about that
Dec 04, 2015 | Hoover Vision HD VHC691B White Electric...
Lg dryer check filter light wont stop blinking and the dryer wont work
You may have a clogged vent line.
Which will cause the check filter light to go on sometimes.
If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged.
And you will not get heat either.
Check that the flexible vent line behind the dryer is not kinked or crushed.
A simple way to check if the vent line leading out from the dryer to the out side of the house is clogged is to remove the vent line from the rear of the dryer.
If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door.
sometimes the little door outside the house gets stuck closed due to lint build up.
Or anything can be in the vent going into wall too.
Oct 20, 2012 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
3H error code on Maytag 2000 washer?
This mode is used to verify the behavior of the washer along the
operation of a normal cycle. It allows you to know the current status
of many switches, actuators, valves, and relays. It also reports the
current values of the drum speed, unbalance value, and power
used by the MCU.
You must have to call some service tech from the company for fix it.
God bless you
Sep 27, 2012 | Maytag Epic Z and Performance Series 2000...
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
I have a fridgedaire front load dryer (Model AEQ6700FS0) and it will start up, run for about 30 seconds and then it stops tumbling and the 3 lights on the far right (drying, cooldown, extended tumble)...
This is just a guess in a way, as I don't have specific knowledge about your particular model, but could it be a wrinkle prevention feature? I know some dryers have a feature which will cycle the dryer on for an occasional short tumble if the regular cycle ends and the clothes have not been removed. Opening the door might be all it takes to cancel the function.
Jun 30, 2011 | Dryers
I have a Zanussi washer dryer which suddenly stopped tumble drying. It is showing code E10, which the manual says is blocked inlet hose. I don't think this can be right, as the wash cycle is working...
it could be the cold water solenoid not allowing much nedded water into the condensor unit... i would check both the hot and cold water feed if both ok and allowing free flow of water into the system have somebody check the poer to both the solenoids if they working ok and allowing water in then check the water pipe from the solenoid going to the condensor which should sit at the backof the machine if this is blocked ornot allowing water to the condenser unit for what ever reason than that could cause the error...i ope thiss is off help kv
Nov 27, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
Machine not start with blink led
turned off the resistance of the dryer
Dec 07, 2009 | AEG Washing Machines
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Tumble dryer getting too hot
It sounds like your vent tube is blocked or kinked. Look at the back of your dryer and you will see that tube coming out. Make sure that it is not kinked. If it is, make it not so. You may have to pull out the dryer to make room. If that is not the case, check the following:
  1. Follow the tube to where it goes outside and make sure it is not blocked. Sometimes critters will build a home in the nice warm tube.
  2. Make sure your lint collect in the door is cleaned out.
One of these suggestions should do it.
Good Luck!
Oct 14, 2007 | Bosch Classixx WVF 2402 Front Load...
Washing Machines Logo
207 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
