Question about Behringer Europower Pmp5000 Powered Mixer Pmp5000
Behringer pmp4000 keeps dropping an ouput channel while playing live!
My B channel will just stop working. Sometimes a restart gets is up again.... Whats the deal?!
  • Behringer Master
  • 5,603 Answers
The PMP has an electronic overload protection. If you overload one or the other of the outputs, it trips the protector and you have to cycle the power off for a bit to reset it. You haven't mentioned what speakers you have. Be aware that the impedance can be no lower than 4 ohms on either channel. In addition, I have seen some particular speakers that have transformer attentuators in them that this amp is NOT happy driving. You could not attach more than two 8 ohm speakers to each of the outputs without tripping the protector.
Posted on Mar 03, 2012
2 Suggested Answers
  • 5603 Answers
SOURCE: Behringer pmp4000; not getting much
You would get about 200 Watts RMS per side using 8 ohm speakers. "Not much volume" is very relative. With the two 12 inch speakers you should be able to fill a 600 to 1000 sq ft room nocely.
Posted on Mar 05, 2011
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
How do i connect focusrite to europowered pmp4000
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
Feb 12, 2014 | Behringer Europower Pmp5000 Powered Mixer...
HOW DO I HOOK UP PASSIVE MONITORS TO BEHRINGER PMP4000
If you are using the amp in stereo mode, then you will require a separate amp for the monitors and the input of that amp are taken using BALANCED TRS cables from the monitor jacks. If you are using the amp as MONO and monitor, then connect NO MORE than two 8 ohm speakers to the Speakon plug on the back labeled for use as monitor. Refer to your user manual... they have detailed photos of the connections. If you lost your manual, you can download another from the Behringer site. There are settings you need to do to configure the unit after connecting your speakers. The small slide switch has to be set to the center position for Main/Mon. Make sure it is centered as many people have had it slightlyu off and the system will NOT pass audio. You need to set each channel "monitor 1" level control to send the monitor signal to the MONITOR mixing bus. You will then use the MONITOR 1 slider to control the amount sent to the monitor. Be VERY careful of grounding the sleeve of 1/4 inch jacks that originate at the Speakon power amp outputs as the SLEEVE of channel A is the HOT side and you can blow the power amp for the channel... it is EXPENSIVE to repair.
Sep 30, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Pmp4000 unit. can i designate different effects to different channels at the same time?
only 2 effects can be used at a time. you assign the effects in your lil digital section in the master part of the board by turning the black knobs so the lit up numbers change to the effect you want then push the black button to lock it in. at which 2 of your aux's ( the last 2 i think its 5 and 6 ) control the SEND to your EFFECTS and the fader below the selections control the amount of effects goes into the MIX.
Aug 31, 2011 | Behringer PMP4000/B1520 PRO Mains &...
I have recently bought a Berhinger PMP4000, I set it up with an SM58 through mic input 1 but can get hardly any volume ? Please can you advise where I may be going wrong ? I am running the power amp with 2...
Things to check: You are using XLR mic cables... You have the speaker switch in the uppermost position A and B mains... the mute for that channel is off... For an SM58 the TRIM for that channel will be at about 3 o'clock to near full on, depending on vocalists voice strength... The CHANNEL fader will be at around -5 to 0 (75% up)... The MAIN fader will be around 50 to 80% depending on how big a room you are in. I assume the Peaveys are on separate channels IF they are 4 ohm speakers. The A and B outputs have a MINIMUM load of 4 ohms. With 4 ohm speakers you can get 400 Watts per side... about 250 Watts with 8 ohm speakers. DO NOT SET SPEAKERS to bridged mode... ALSO please read my tip on Fixya about a hazard of channel A polarity if you use 1/4 inch plugs on the ends at the speakers. The SLEEVE of channel A is the HOT, not the tip and grounding the sleeve can blow the channel A amp.
Aug 21, 2011 | Behringer PMP4000 / B212XL Mains Monitors...
Behringer pmp4000; not getting much volume from system 2 speakers going through main 1 out both L R A/B switch is to the top main L R tried guitar computer in channels 9/10 via rca still minimal...
Mar 05, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
I just purchased A behringer PMP4000. It has built in effects. When I follow the steps to add fx , as soon as I start turning up the fx send, It sounds like sweeping wind through the mains. How do I use...
Check the FX to main level to make sure it is not too high. Also check the main FX fader level. Try turning each of these down and see if that corrects the issue. The FX fader should control the volume level of the FX globally (mon sends as well as main outs), and the FX to main should only affect the mains output. Make sure FX to mon1 and FX to mon2 are turned all the way down.
Also check what FX program your using and that the FX IN button is depressed, try starting w/ #10 (small room) and see how that sounds.
Feb 28, 2011 | Behringer PMP4000 / B215XL Powered Mixer...
Where (on-line) can we find download for advanced manual for Behringer PMP 4000 16 channel powered mixer? What we found on-line was the exact manual that came with the mixer.
There really ISN'T and "advanced" manual... Everything you need to know is in the user manual that comes with it... Service manual with schematics will not give you much you can use unless you are into electronics detail.
PLEASE read my tip about Behringer PMP mixers on here regarding a hazard if you use Speakon to 1/4 inch cables or adapters. Essentially, the sleeve, NOT the tip is the HOT lead for a speaker on channel A. Ground it inadvertently and goodbye channel A amp.
Be VERY careful of speaker leads with this amp as it is easy to pop a channel IF a speaker comes loose or shorts. Loop cables through the handlesto avoid cables being yanked out or breaking plugs.
Feb 09, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
I want to know where i can get a new fuse for my pmp 5000b-212XL powered mixer ?? and waht kind of fuse is it ?
If the fuse has blown DO NOT replace it without repairing the cause of the failure. You will likely do more damage to internal components. Take the unit for repair before applying power again. I have repaired many of these and first a failure occurs in one of the power amps... usually the A channel, then people replace a fuse that protected the power supply and that blows the power supply taking out another $30 of components and $200 labor. (they are hard to change) If the unit is under warranty, exercise your warranty immediately. There is a weak spot in the channel A power amp.
ALSO please read my tip on here about a hazard in PMP series powered mixers. It is in regard to using Speakon to 1/4 inch speaker cables... NOTE that the BARREL of a 1/4 inch speaker cable or adapter from the Speakon is the HOT side for channel A and if you ground it inadvertenly, goodbye channel A power amp!!!
Jan 04, 2011 | Behringer PMP4000/B212XL Mains & Monitors...
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Logo
181 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
