Question about Rio Forge Sport Digital Media Player
Rio forge problem
Shows "upgrader" after turned on detected on windows as removable disk but when you double clicked that drive it show "pls insert a disk into drive e" pls. need your help.. thanks..
Go to: http://www.sonicblue.com/support/rio/downloads/Forge/RioForge_firmware_133.exe download the latest firmware. Follow the instructions. **NOTE** Make sure you have a new battery in your RIO as well. I've seen a low battery being a problem.
Posted on Nov 15, 2006
My rio forge player is showing "upgrader"
When mine did this it meant the firmware inside had gotten corrupted. It started working again when I reinstalled the firmware. The official firmware is available at the official website, and wikipedia promotes an unofficial firmware that provides more features.
For either of them, plug the unit into the USB port of your computer, then run the utility to upgrade the your Forge.
(Eventually, my Forge's internal memory storage died - it still play music from card memory, but every time I turn it on I have tell it my language is english etc.)
I hope that helps.
Oct 27, 2009 | Rio Forge Sport Digital Media Player
After insert Pen drive it detects drive but double clicking on that it shows message "insert disk drive G:"
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Sep 30, 2009 | PNY Technologies GeForce 6200 128MB AGP...
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
2 probs
Press the MENU and turn it on, as soon as the word RIO shows on the screen release the power button but do not release the MENU button until it says upgrading
Plug the USB cord to it and install Rio Forge Firmware_120
Turn the mp3 off then on normally
Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
hope this helps,
trin
Nov 19, 2007 | Rio Forge Sport Digital Media Player
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
Rio 512 mp3 player
You need to connect the Rio to a PC and then use the Windows Explorer format disk feature to reformat the Forge's flash memory as a FAT32 partition.
Sep 08, 2007 | Rio Forge Sport Digital Media Player
My Rio says upgrader when I turn it on
UPGRADER is a mode that purges the firmware from the Rio player prior to flashing the unit. Firmware is basically the operating system for the player, so if it is corrupted any number of things can occur. You can enter UPGRADER mode to update the firmware on your player by holding down the MENU button when you power the Rio ON. Flashing the player in this mode erases all content. Try the following to get the unit out of UPGRADER mode, if powering OFF the unit will not correct it. ALL PLAYERS - If you accidentally entered UPGRADER mode, turn the unit OFF and then back ON again. - Download the latest version of the firmware for your player and upgrade the unit. Visit http://www.digitalnetworksna.com/support/rio - It may be necessary to run the firmware update more than once. - This process may erase content from your player. - If the player is detected by the computer, it is recommended that you format the player, which WILL erase content from the player. - Macintosh user's try flashing the player on a PC. FLASH MEMORY PLAYERS - Remove the battery and replace it, this will reset the unit. The Rio Forge, Rio se510, Rio Cali [Black Rio Stick], and Rio Chiba [Black Rio Stick] can lock up causing the player to be unresponsive. If this occurs there are two things that need to be performed to resolve the issue. First you want to remove power from the player this includes the battery and a USB connection for 20 minutes to reset the player. There is a capacitor on the player that stores a charge that holds the player in the locked state. By waiting the duration the capacitor will discharge and the player should function as normal. Second you will want to upgrade the firmware to the latest version and format the player to prevent future occurrences. HARD DISK DRIVE PLAYERS - If you have a Carbon, Nitrus, Eigen, or Karma, use a paper clip to reset the unit. Your Rio will power off automatically when it has been reset. It may be necessary to connect the player to AC power and then reset the player if it will not turn on. If you are still unable to have the player exit UPGRADER Mode, then try it on another computer. UPGRADE FIRMWARE - Connect to the internet - Go to http://www.digitalnetworksna.com/support/rio/ - Click on the appropriate player - Click on the FIRMWARE tab [showing by default] - Click on the latest firmware file [example: RioForge_firmware_133.exe] - Click SAVE when prompted - From the SA
Feb 14, 2007 | Rio Forge Sport Digital Media Player
Internal memory unknown format
Turn it on holding the MENU button, connect the usb cable and update the firmware that u can download from www.rioaudio.com, that will fix it.
Dec 15, 2006 | Rio Forge Sport Digital Media Player
Rio 258 cannot connect to computer
1. go to http://www.digitalnetworksna.com/support/r....asp?prodID=213 and download update 1.33 2. install update in C:\RioForge\Flash133 3. run RioForgeFlash_133.exe from C:\RioForge\Flash133 4. press Rio Forge menu button and turn the unit on. "upgrader" will appear on screen. 5. plug USB cable to RioForge. 6. click "next" on Rio Upgrade Wizard. Wizard will detect your player. Select and click "next". Upgrade will take place. 7. Unplug Rio Forge from USB and turn it on. Voil?!
Oct 12, 2006 | Rio Forge Sport Digital Media Player
I know this request is old, but I found it while searching for an answer to the same problem myself. First you need to go to the Rio site and download the most up-to-date firmware. it DOESN'T matter if it's the same version that you have now, you will need the installer program. Download that and install it. Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen. Now, run the firmware upgrade program and it will see your player and upgrade the firmware (yes, even if it's the same firmware version. You have to do this step). Once it's completed, unplug the player from your computer and the darned thing works.
Jun 30, 2006 | Rio Forge Sport Digital Media Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
132 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
