Question about Maxtor Hard Drive
Maxtor ide drive powers on reads as only 0mb in bios..
I have a maxtor 4g160 ide ata 133 drive , it powers on detects inself as maxtor romulus and 0mb in bios, will replacing the pcb board of exact drive /size/firmware code get this drive to read? thanks appreciate any ressponses its been this way since nov 2004 i spent many hours reading hard drive problems and one i saw seemed odd but seemd to work to temporarily restore use to a dead drive by placing it in anti-static baggy and then placing in freezer for 12 hrs ? i did not try this.. i may try this if replacement of pcb does not work.. either way if it doesnt work ill save the drive mabye 20 yrs from now itll be so EASY to fix thanks for reading this
rulds2008
  • 3866 Answers
SOURCE: Dead Maxtor drive
the soec of the drive will have to match up in order to get the no pcb to wrok so the heads ,sectors,cylndrs and so forth
Posted on Apr 23, 2009
Bubbabear64
  • 2794 Answers
SOURCE: Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Posted on Jun 10, 2008
zzptichka
  • 95 Answers
SOURCE: New PCB power circuit. Can't find one?
I don't think it would be worth it...
Posted on Dec 30, 2008
anaesarora
  • 180 Answers
SOURCE: maxtor one touch iii unable to read drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Posted on Sep 06, 2009
gripfitter
  • 557 Answers
SOURCE: Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Posted on Dec 11, 2009
My Maxtor DiamondMax Plus 9 80GB ATA/133 HDD with a X-Media USB2.0 TO IDE & SATA cable adapter
Check (under high light) flat IDE cable pins on the mini-board. Many pins, and many chance to loose contact.
Feb 10, 2014 | Computers & Internet
Romulus Hard Drive name
check the bios can see it or check the jumpers are fitted correctly on the drive. slave or master ? check cables connected properly, power and ide cable
Dec 24, 2013 | Maxtor DiamondMax D540X 40 GB Hard Drive
Is the maxtor diamondmax 10 250gb ide hard drive compatible with the intel d865gv socket 478 motherboard?
It should...Maxtor drives can be a bit finicky on older systems. This drive supports the ATA-133 standard. Your board does not. It should work but run at the lower ATA-100 rate.
Jan 31, 2012 | Intel D865GBF Motherboard
Ultra ata 133 ide controller........i installed this on a brand new gigabyte MB with windows 7..........Device manager knows its there but with a problem. I cannot locate drivers for this device...
if u cant locate the drivers name, try using unix base(linux) live cd's, like knoppix for example, they usally detect all the drivers u have in minutes and even gives u all the names and serial numbers, then u can download them.
Apr 30, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
Is the maxtor 6y120p0 a ata or sata format
Maxtor DiamondMax Plus 9 120GB 7200RPM IDE Ultra ATA-133 3.5-Inch Internal Hard Drive Mfr P/N 6Y120P0
thanks and regards
kindly rate this solution
Oct 28, 2009 | Computers & Internet
Dead Maxtor drive
Apr 23, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
HDD unable to detect at My Computer
Well first I would pull the hard drive out of the case. I would then get a USB to IDE/SATA drive cable. I would connect the drive not being able to be detected to another computer via USB.
If it works the drive is still good but the data might be corrupt. If the data is corrupt I would be sure to get any stuff you can off of it and basically reformat and reload.
Mar 13, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Hello, I have a PCI Ultra Ata/133 Dual IDE card. I have two Ide devices hooked to it. Everytime I hook it up in the system My regular Motherboard IDE says can't be read, reboot. I am trying to get not Raid...
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Jan 12, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
Maxtor Hard Drive Logo
312 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
