Question about Frigidaire FDE216RE Dryer
Belt replacement - possible missing part
I need a diagram for proper belt installation at motor - I think I may have a part missing that keeps the belt tightened. It is a used dryer that's been in storage. My sister told me the only thing wrong with it was that the belt was slipping. There was a spring laying in the bottom under the motor but didn't appear to be anything to attach it to. She no longer has the manual so I have nothing to look at to attempt to repair it and replace the belt. Can you help?
  • wolfj Oct 27, 2008
    Thanks!! That was very helpful!! I appreciate your very timely response!!!!
  • 5,911 Answers
There are some excellent exploded view illustrations you can use for a reference at searspartsdirect.com. Just type in your model number and look under the link on the following page. There is also a zoom feature so you can get closer views if needed.
There are also helpful dryer belt diagrams listed at repairclinic.com. Just click on the "Repair Help" link at the top of the page and look for the "Dryer Belt Diagram" link on the following page listed under "Special Features". The Fridgidaire diagrams are listed as C, B, and G. You will have to know the age of the appliance to make sure the diagram you are using is accurate. If you do not know the age, please post back with your SERIAL number and I can tell you how old it is. I hope you find this information helpful.
Posted on Oct 27, 2008
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Is it possible to tighten a loose belt on my cub cadet RZT-54 ZERO TURN RIDER.model number 17AFCACK009
HI,
I assume you are reffering to the mower deck pulley...however, the belt that drives the two hydraulic motors work the same way as deck pulley system.
First, there is no manual adjustment on the pulley system. Rather there is a spring loaded pivot arm to which an idle pulley is fastened to. The spring pulls the pivot arm in such a way the it forces the idle pulley to keep the belt tight at all times. The same setup is used on the ground drive belt.
Sometimes these springs become disconnected or break so that no tension is placed on the belt to keep it tight.
Check the tensioner spring to ensure that it is connected properly and applying tension to the belt. Otherwise, you may have the incorrect belt installed, the belt is routed incorrectly or the belt may be stretched out and need replacing.
Here is a diagram to clarify, the spring is the dark black item;
Here is a link to a large diagram that is easier to read;
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Jul 14, 2014 | Garden
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
Tip
Inglis Dryer Belt Diagrams and Replacement
All models use this diagram:
Installation Tips: Ribs against drum
Tip
Franklin Dryer Belt Diagrams and Replacement
Tip
Magic Chef Dryer Belt Diagrams and Replacement
Tip
Maytag Dryer Belt Diagrams and Replacement
For all single belt models use this diagram:
Installation Tips: Flat side of belt against drum
Tip
Norge Dryer Belt Diagrams and Replacement
Tip
RCA Dryer Belt Diagrams and Replacement
Dryers Logo
109 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
