Question about Thermador PRDS364GDUS Dual Fuel (Electric and Gas) Kitchen Range
Trying to find a griddle cover for my 10 year old Thermador PRDS364GDUS.
Where can I find a griddle cover original part # PGRIDCOV. There is a new griddle part # PA12GCVRHC but Thermador said it wouldn't fit my griddle.
2 Suggested Answers
SOURCE: Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
Posted on Jun 03, 2009
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
try this.
Leslie
Mar 19, 2009 | Thermador PRG484GGUS Gas Kitchen Range
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Smoke Coming from inside of Microwave even when warming for 10 seconds
Proberly wave guide cover at side it can get grease behind it,And when you used it with small load it tried to cook it and then burned the mica cover,Take mica cover off and try it without it to seeif problem resolved if ok,New cover can be obtained if req.Regards grandadfixer
Oct 10, 2008 | Thermador MBBS Microwave Oven
Both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Mar 21, 2007 | Thermador PG484GGEBS Stainless Steel...
Thermador PRDS364GDUS Dual Fuel (Electric and Gas) Kitchen Range Logo
114 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
