Question about RCA Televison & Video
Service manual access and description
HD27F754T 27" flat 4:3 HD CRT w/HD tuner I'm looking for the procedure to gain access to the service menu as well as any description of the menu items within (I have searched the 'net extensively). If this info cannot be provided then is it available in a service manual? (I'd like to know before spending the money on one as this info may not be in the service manual). Thanks!
3 Suggested Answers
  • 979 Answers
SOURCE: Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Posted on Oct 20, 2007
  • 4234 Answers
SOURCE: Service Menue
Getting into the service menu is normally discouraged unless you have the service manual. Even relatively simple changes such as those you wish to attempt need to be made in the correct order and fashion. A factory remote is required for this as there is a specific sequence of commands required. If the only problem is a slight tinting of the picture, this should be "fixable" using user level menu options. Please further describe the problem you are having and I'll try to guide you through the changes that are needed.
Posted on Feb 21, 2009
Emerson EWF2006 TV access code
if your tv doesnt have a digital tuner, you cant, unless you have a digital to analog tuner converter (can be purchased in walmart, or other stores that carry tv s, electronics) you tune your tv to 3 or 4, use the converter box to scan for channels, and for changing channels instead of your tv tuner
Mar 21, 2013 | Emerson EWF2004 20" TV
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
Is freeviewhd included in inflatron m2780d
If you're referring to LG's 27" LED (LCD) Monitor.....
According to specifications, this panel has both the Analogue AND Digital tuners built in.
However, the Digital Tuner is NOT the Freeview type.
Instead, the built-in digital tuner is of the standard DVB-T/DVB-C type, which works off the following frequencies:
Horizontal: 30 - 83kHz
Vertical: 56 - 75kHz
Which means you can access what everfree broadcasts are available within those frequencies.
Hope this helps you understand.
"Please rate this solution"
Dec 28, 2011 | LG Televison & Video
RCA F27442 - Cable showing up "snowy". Found tv outside, so maybe it's shot, but wanna chk just in case. Anything other than what 'Menu' offers can help - something physically inside...
Real common problem with RCA, bad connections in tuner/ if module, Solder tuner and if module and leave shield off tuner and solder main grounds around tuner.
Aug 15, 2011 | RCA F27442 27" TV
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Is the rca true flat tv able to be used by putting up an antena -or will we need a convertor box ? currently we have direct tv and are thinking about canceling it and use an antena.
This model does not have a built in HD tuner (ATSC Tuner). You would need an HD antenna (that is a more recent antenna that receives UHF) and an HD converter box to get the newly broadcast HD signals.
Nov 06, 2009 | RCA TruFlat 27F520T 27" TV
Tuner Mode - Air or Cable?
Direct tv, unless using there HD service will give a pretty crappy picture for high res displays. So if you spent the money on the set, spend the extra $9 a month for there HD service.. Is well worth it.
Apr 20, 2008 | Astar LTV-27HBG 27 in. LCD Television
4 digit access code put in by previous owner. blocks some channels
use 0711 Hope that works. If you need more details I could email a portion of the service manual covering that procedure.
Nov 13, 2007 | Philips 27PT6441 27" TV
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
