Question about GE WSXH208A Front Load Washer
Washer not rinsing or spinning but doea go around
My front GE load washer will wash but when it comes time for the rinse and spin just continues to keep same water an the soap and does not rinse nor is it spining out. Please can you give suggestion?? It goes arund as if it is doing it's thing but still has same old water and soap. thank you for any help! Have a blessed day!
  • LISA OAKES Aug 29, 2006
    Thank you!!!! Thank you!!!! You are such a blessing!!! Yes there was something in the hose leading to the pump impeller clogging it $10.00 in pennies, nickles, dimes, and quarters. Who would have guessed! Then the impeller was still not working so my husband took it out and a hair barrett was lodged in it. Needless to say we are going to have to explain to the people living in our house to standards to washing laundry. #1 just empty all your change in our change jar to prevent the work of cleaning up all the water (the floor needed a good scrubbing anyway) #2 no more hair barretts!! We are so thankful for your fast response thank you!!!
    Can I ask one more question? My door pops open ever once in a while. Could it be that I'm using to sudsy of laundry soap or that my door latch is just warn out? If the later are they easy enough to change? Have a Wonderfully Blessed week! (You sure have helped to make ours!!!)
Great solution Catriver! My problem: drum rotated during wash, but did not drain. Checked the trap. Found 15 coins, 2 nails, keychain, and a piece of wire. Cleaned it out. Fixed the problem. My contribution: visually check for other problems, leaks, etc. I found a broken shock (strut, dampener). Tip for GE front load: buy the Frigidaire parts (same parts without the GE markup). The Frigidaire struts sold by the pair, with extra pin, and installation instructions. The instructions can aid in removing the broken parts. Also, watch out for those sites that sell the struts individually for the price of 2 struts. Chao!
Posted on Nov 22, 2006
    President:
  • 878 Answers
Loakes, the first thing you want to check is the drain pump. Remove the lower panel and it will be on the right. If the pump is not working the washer of course will not drain and will not go into high spin speed. You will need to verify that first it is getting voltage and second there is nothing jammed in it. Get yourself a pan and a bunch of towels and remove the hoses to it. You will have a lot of water coming out at you. Check the pump impeller and see if something is caught in there. If you still have problems after doing this, some tests will have to be made to determine the problem...Catriver..post back.
Posted on Aug 28, 2006
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
heatman101
Apr 14, 2011 | GE Washing Machines
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE WSXH208A Front Load Washer Logo
751 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
