Question about Lands Phones
Axxess phone system..no trunks in trunk group
  • 108 Answers
SOURCE: Samsung DCS 40 Prostar
Could you repost your question and tell me the type of phone system you have, you say it is a DCS 40 Prostar but I do not recall the 40, only the 408, 612 and 816. also MMC 601 is for station groups and 603 is for trunks. I'll be glad to help if you can clear this up for me. Thanks, .....Mike
Posted on Jul 31, 2008
  • 7 Answers
SOURCE: VW Jetta 2003 1.9 TDI trunk does not want to open with remote
If your lock actuator engages (you can hear the sound it makes) with the remote/electric button on the door, but the trunk doesn't open then the problem is likely a broken plastic arm that the electric assembly pushes. You can see it if you unscrew the inside cover from the trunk lid and try the remote. I started having the same issue with VW Jetta 2002 GLS that was rear-ended 8 months ago. My guess is the cracked plastic finally gave out in the cold weather.
Posted on Feb 22, 2009
  • 149 Answers
SOURCE: trunk to trunk transfers
The feature has to be allowed in class of service. you must than hit transfer, dial a 9 than the full number. you need to know how to program the phone system to change class of service. ldtsnj.com
Posted on May 02, 2009
p_murfy
  • 63 Answers
SOURCE: trunk locking/unlocking system not working. Cant get into trunk
if you have a newer 07 and on, there is a lock cylinder near the trunk grab handle. you will have to kneel down to be able to see it. the mechanical key thats inside the remote will have to be used. a spare/valet key wont work. support your local bmw dealership
SOURCE: trunk release for 2000 mercedes s 430 not working properly
Trunk can be lock separate from the doors valet try unlocking the trunk with the key lock it with the door.Read the owner manual it will tell you about valet parking.
Posted on May 20, 2009
When calling out display reads ARS unavailable
ARS Unavailable means your trunks are all busy or they are down or not working from the telephone company,
Oct 07, 2010 | Inter-Tel Axxess Corded Phone
Won't trunk track. Searches frequencies, but will not scan talk groups.
This radio will only work on analog trunked systems, if it is a digital or P25 system, you need to upgrade to a digital scanner like the PRO96, or newer.
Jul 13, 2010 | Radio Shack Pro-94 Scanner
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a Kx-TD1232 pbx and would like to activate the 2nd music on hold feature. any ideas of how to handle that?
This should be an audo response...the one with the big horse laugh :-)
Panasonic TD's have 4 music sources, BUT there is no tenant service. You can play SOURCE 1 to trunks and SOURCE 2 to BGM and external page, but you can't play Source 1 to trunks 1-3 and Source 2 to trunks 4-6. A TD has no tenant service. That was addressed in the TDA system.
System programs 803 and 990 control how the music is played and where. There is external equipment that can split music to different trunk groups. It's expensive so the upgrade from a TD to a TDA might be a better option.
Carl
Dec 14, 2009 | Panasonic KX-T7453 Corded Phone
Need to transfer hunt phone lines to answering service
Make sure that you have allow analog trunk to trunk connect enabled in lines, analog options.
That will take care of your problem unless someone deleted Call forward short code
Apr 14, 2009 | Avaya 5400 Series 5410 Phone
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
On my scanneri have trunking what is that
trunking is a system where many radios use a few channels, the radios scan through the channels and find one that is not busy, then when you key up the transmitter it sends out a signal to the other radios in the group and switches them to the same frequency. There are at least 3 different trunkings systems that i know of, maybe more by now, but this is a basic explanation of how they work.
Dec 29, 2008 | Uniden BC60XLT Handheld Scanner
Jul 28, 2008 | Samsung Prostar 816 Phone
Programming the DSS/BLF
Need to login in system and program buttons from there.
Nov 07, 2007 | Inter-Tel Axxess Phone 5504400
Lands Phones Logo
50 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
