Question about Inter-Tel Axxess Corded Phone
No trunks in trunk group
Phone is dead, the only response is no trunks in trunk group
Bentley Boot lid manual release
This is all the Bentley shows:
Location: Driver's side door trim in storage compartment.
Removing:
- Remove driver's side door trim:
Repair Manual, Body Interior, Repair Group 70 - Unplug connectors.
Carefully disengage catches -arrows-.
- Press switch for interior monitoring and towing protection -1- or trunk release switch -2- out of trim toward rear.
Installing
Installation is carried out in the reverse order.
Remove trunk lid lock.
Repair Manual, Body Exterior, Repair Group 55
- Use a flat screwdriver to pry plastic tab -3- off retaining pins -1-.
- Bend plastic tab fully to rear.
- Pull contact switch -2- first sideways and then up and out of trunk lid lock.
Installing
Install in reverse order, paying attention to the following:
Note:
Make sure that washers are correctly seated between plastic tab and trunk lid lock.
Sep 01, 2012 | Bentley Continental Flying Spur Cars &...
2004 Lexus LS 350 keys in trunk battery dead
I would have the dealer cut a new key to get the driver's door open - or use a spare. You can buy a small charger that plugs into the cig lighter.
Aug 03, 2012 | Cars & Trucks
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a Kx-TD1232 pbx and would like to activate the 2nd music on hold feature. any ideas of how to handle that?
This should be an audo response...the one with the big horse laugh :-)
Panasonic TD's have 4 music sources, BUT there is no tenant service. You can play SOURCE 1 to trunks and SOURCE 2 to BGM and external page, but you can't play Source 1 to trunks 1-3 and Source 2 to trunks 4-6. A TD has no tenant service. That was addressed in the TDA system.
System programs 803 and 990 control how the music is played and where. There is external equipment that can split music to different trunk groups. It's expensive so the upgrade from a TD to a TDA might be a better option.
Carl
Dec 14, 2009 | Panasonic KX-T7453 Corded Phone
DTU16D-2 Multiline issues
You need to enter program mode. go into MB 4-12 for your port number and remove line keys 3 and 4 from your phone. You should also remove the 2 dead lines from the trunk group so no one can access them. 3-03.
ldtsnj.com
Jun 09, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Dead Battery on MB c230, how do I open trunk?
hello,you can open your trunk by your mechanical key,then red cable to positive and black to negative,ty
Apr 18, 2009 | Mercedes-Benz C230 Cars & Trucks
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
Samsung DCS 40 Prostar
Could you repost your question and tell me the type of phone system you have, you say it is a DCS 40 Prostar but I do not recall the 40, only the 408, 612 and 816. also MMC 601 is for station groups and 603 is for trunks. I'll be glad to help if you can clear this up for me. Thanks, .....Mike
Jul 28, 2008 | Samsung Prostar 816 Phone
Inter-Tel Axxess Corded Phone Logo
293 people viewed this question
Top Inter-Tel Lands Phones Experts
David Burbee
David Burbee
ray gallant
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
