Question about Car Audio & Video
Instructions to install a panasonic CQ-VAD7200U car radio
backinblack
  • 11 Answers
SOURCE: Installation
Yes, if your explorer's stock radio is bigger than the other, just get an adapter kit, walmart, ebay ect., and a wireing harness adapter for that model. Then pull it out and start wiring it up.
Posted on Feb 23, 2008
murdozzz2
  • 75 Answers
SOURCE: panasonic cq-c1323nw reset button
hi there type your model number into this link and you can download the user manuall, i've tried it for your model no and it works.
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Posted on May 02, 2008
SOURCE: CQ RDP162N
i can get a general wiring diagram for now need to look into it sum more
Typical Head Unit Wire Harness Function Typical Wire Colors Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Posted on Dec 31, 2008
  • 28 Answers
SOURCE: How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Posted on Mar 25, 2009
etirbynnor
  • 655 Answers
SOURCE: I need to install it to my camry 93
Hello capello,
Here's a link to the Camry color codes:
http://www.modifiedlife.com/1993-toyota-camry-car-radio-stereo-wiring-diagram/
If you do not want to cut or tap into the vehicle wiring, you should buy an aftermarket adapter harness and splice the wires from it and from your Panasonic CQ-C1100U together.
The Scosche part number for your Camry is TA02RB. Wiring harnesses are also made by Metra and others. Here's a link to the Scosche part:
http://www.bestbuy.com/site/olspage.jsp?skuId=9074137&type=product&id=1218016141744&ref=06&loc=01&ci_src=14110944&ci_sku=9074137
Hope this helps.
Posted on Apr 20, 2009
How to install a panasonic cq-c8303u
You might need a few things to install your radio. You will need a wiring harness, install kit, and instructions. You can find specific wiring harnesses and install kits at www.crutchfield.com and you can purchase instructions at www.sound-repair.com Hope this helps
Aug 23, 2011 | Car Audio & Video
Security code
If you still have the original receipt for the unit, check with an Authorized Kenwood dealer first to see if they can do it. If they can't, the manufacturer can. However, you have to show Proof of Purchase via original receipt. Otherwise ... Don't bother buying it!!!. Hope this helps
May 21, 2009 | Panasonic CQ-VAD7200U Car DVD Player
Volume won't turn upon my panasonic cq-vad7200u car stereo
this may be a pre amp only deck
and if it is ou have to buy amplifiers to make the speakers work
May 07, 2009 | Panasonic CQ-VAD7200U Car DVD Player
Panasonic cq-vd7003u ipod video trouble
The problem is that the panasonic cq-vd7003u does not support that function which sucks cuz i have one 2 the slightly newer verision PANASONIC CQ-VD7005U does have that feature. so sorry.
Mar 30, 2009 | Panasonic CQ-VD7003U Car DVD Player
Ipod
well you can't do that using your ipod.. try using a dvd if you want to use your dvd player for your videos and music..
Jan 24, 2008 | Panasonic CQ-VAD7200U Car DVD Player
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
