I've had my GE front loader for about 15months. All was fine until my last load of wash. When I went to remove the clothes, the rubber boot was completely out of shape and the rubber is breaking apart. Why would something like that happen. There was nothing in the machine that would cause that, as all were delicates. Has this happen to anyone else?? I'm told the price to replace the rubber boot is over $100.00. And is this something I can install myself?
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
My washer won't complete a wash cycle. They clothes stay dripping wet. I have to turn it to drain...
(More)
My washer won't complete a wash cycle. They clothes stay dripping wet. I have to turn it to drain and spin to get the clothes to only be damp like they should be.
the past week i noticed i had to "slightly lift the door to close"prompted me to look at...
(More)
the past week i noticed i had to "slightly lift the door to close"prompted me to look at the hinge and i noticed a large crack in the upper plastic casing on the door.....is this a wide spread issue?
sin cycle does not spin clothes out entirely during the highest speed of the cycle. Clothes come out...
(More)
sin cycle does not spin clothes out entirely during the highest speed of the cycle. Clothes come out semi dry. As well, on the spin cycle only, the timer goes to 8 then goes back to 11 on the timer so it starts again, rather than going to the end of the time allotment jean
