Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Oil Filter part number for Cub Cadet LT1042 Kohler 19hp engine
I need to find Oil Filter part number for 19hp Kohler Engine
4 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: Cub Cadet Riding Lawn Mover with Kohler Engine -
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 3074 Answers
SOURCE: Crack in the Kohler engine block for a 2006 LT1042
if you find a good machinist and he/she maybe able to braze it
Posted on Apr 17, 2011
Cub cadet 4621 zx390 single cyl. oil comes out of dip stick tube where is breather located
Find your carburetor assembly. you have a rubber tube coming from that to your to your oil breather. you can also look up your parts manual using the same info you gave here. Cub cadet 4621 zx390. looks like a kohler engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Aug 29, 2017 | Cub Cadet Garden
Oil change
Take the old one out and get the numbers off of it or take it with you for reference. The amount of oil is probably 3 quarts but that can be looked up on cub cadet site.
Jul 26, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cant remove oil filter on Cub Cadet LT1050
grab the filter with a pipe wrwnch or drive a screw driver through it and turn it. good luck. Ron
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
I changed the oil on my cub cadet lt1042, the oil light is still on
THE AIR FILTER SHOULD MAKE NO DIFFERENCE, THE LIGHT MAY BE AN OIL PRESSURE LIGHT NOT LEVEL LIGHT.
May 02, 2012 | Cub Cadet Street Sign- tractor lawn riding...
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Kohler courge sv720-0010 on cub cadet
SOUNDS LIKE IT HAS SOME BAD GAS YOU MAY NEED TO CLEAN THE CARB AND IT MAY NEED A KIT
Oct 10, 2009 | Garden
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
467 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
