Question about Ball Joint, Tie Rod, Pitman Arm Seperator Set
Suspension on a lincoln ls 2001 8 cylinder - Ball Joint, Tie Rod, Pitman Arm Seperator Set
My 2001 lincoln ls v8 has a delay wheel turn likewhen you turn your wheel sharp the steereing wheel gets loose feeling and the wheel dont turn as good as it suppose to be any ideas what it might be?
Front steering / suspension is only as good as its weakest link. There are many components working together that can be problematic here is a list of liikely culprits & things to check, tried to put easy stuff first:
  • tire pressures
  • steering fluid
  • worn/loose steering rack
  • tie rod ends
  • column u-joints
  • suspension - struts, joints, bushes components & integrity
Jan 08, 2015 | 2001 Lincoln LS V8
Engine code for 2003 lincoln ls v8 is coil pack h. wihich cylin der is that?
Invalid Code on a Lincoln L/S 2003 up
Cylinders on Fords go
A,B,C,D,E,F,G,H
1,2,3,4,5,6,7,8
PO301,PO302,PO303 etc
All the same thing
PO308,Number 8 & on other fords H---are the same
Aug 24, 2014 | 2001 Lincoln LS V8
Are the spark plugs under the top of the motor on my lincpln ls, and if so will i need a gasket to put back on when i change them
the coils act as the gasket but the valve covers can leak oil into the chamber for the sparkplugs and give driveability problems. there are gaskets for the valve covers that can correct this if you have oil in there. yes thye sparkplugs are in those recesses
Apr 20, 2013 | 2001 Lincoln LS
What does it mean replace upper and lower ball joints tie rods 2000 lincoln ls
they are front suspension pieces, and yes it is costly, but its not just the parts, there's labor also, and another mechanics opinion would be good.
Mar 10, 2013 | 2001 Lincoln LS
I have a 2001 Lincoln LS that needs an engine. Wh...
The LS and Ford T-Bird -only.
Only Ford 3.9 lt V8
Don't know on the V6
May 21, 2010 | 2001 Lincoln LS
A motor runs with no one in the car
The cooling fan on the radiator is being turned on by the radiator temp switch. This is normal. It keeps excessive heat and pressure from building up inside your engine. Excessive heat can cause radiators to overflow or hoses to burst. It is NOT a bad thing for that fan to be running for 2 - 3 mins.
Apr 13, 2010 | 2001 Lincoln LS
It is on the Driver side of engine in between the COP's (Coil on plugs) simply unplug the wire use a 19 or 3/4 deep well socket and unscrew it and put it new one... The whole process should only take 10-15 minutes.
Jan 11, 2009 | 2000 Lincoln LS
Engine sputter
2002 linclon ls 3.0 v6 pcv location
Jul 16, 2008 | 2001 Lincoln LS
Ball Joint, Tie Rod, Pitman Arm Seperator Set Logo
Top Lisle Vehicle Parts & Accessories Experts
Rigger
Danny
Kar Volk
Are you a Lisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
