Question about LG M2280D 22 in. LCD TV
Tv screen is reddish / purple
Hi I'm new to this so hopefully I haven't posted twice. I got my tv for Christmas and it has been working well. I came home after a weekend away and turned it on to find the colours are all very severe.I have upc installed too so maybe that's the problem? Pretty much anything thats meant to be white is purple, all the colours are very very extreme and tinted red / purple. I have reset the factory settings for both upc and the tv twice now but it doesnt help. I have tried to mess with the settings myself but all i can do is dull the picture / colours a bit and it's definitely still not right. Can anyone help or give me pictures settings to try out? Is it likely to be a tv issue that needs a repairman rahter than me? is it something i did? any help will be greatly appreciated :)
SOURCE: lg 32lc2r, only showing picture in black and white
I have sharp tv did same thing menu's have color, and only black and white picture
Posted on Apr 02, 2008
jerryg50
  • 1667 Answers
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Posted on Apr 12, 2008
freetek
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
  • 458 Answers
SOURCE: plasma tv has little red dots in the black
This problem (known as sparkles) can be cured by adjusting the ramp control on the Y-Sustain board. If this does not cure the dots then there is a software remedy for the control board which an LG repair centre could fix. Failing that a replacement board is required. The orbitor & whitewash are like screen savers to help to prevent a screen burn from a permanently displayed image.
Posted on Apr 01, 2009
  • 8457 Answers
SOURCE: HI my 32lc2r Lg Lcd tv wont show picture.
Might be ur controller inverter board or main video backlight board.Ur video does show up a picture right?That the only two boards that related to video.My adviced to u is buy the controller inverter board first tried that,if not work return it for money back,but must pay restocking fee.That the board between the power supply and main backlight video board.Than u know for sure it the main video backlight board.
Posted on Oct 22, 2009
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
SAMSUNG LCD 550 SERIES TV COLOR GREEN AND PURPLE
Sounds like t'Con board fault. Contact any service technician to make it confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Samsung Televison & Video
Hi. i cant get the menu screen on my panasonic sc-pt90. and it wont play thru my tv
First and most important thing is - Is it connected to your TV? If it is you might try a different lead. You haven't said if this is a reinstall or a new install. If it is a new install, you should take it back to where you bought it. If it is a Reinstall, then the most likely problems are :- cable or connectors. if a cable replacement doesn't fix it, you might try pluging it into a different connector on your TV. Also make sure you are trying to view it on the correct channel of your TV. Hope this helps.
Nov 28, 2011 | Panasonic Home Theater System System
Model ds31590 screen has a reddish purple tint whether it s on tv or video i have already tried to change all picture settings and set back to factory settings still has same problem,here is an example...
Chances are real good that your picture is showing its age. There are three color beams in the neck of the picture tube. When these electrodes are operating correctly the will produce an arc, that will produce the proper voltage for color correction. Much like the spark plugs in your car. When you have a fouled spark plug, you replace it. In the case of a TV, replacing the tube is the best way to correct the picture you are looking for. It would be to costly to do this of course. Another option is to rejuvenate the picture tube. Once again, rejuvenating the picture is last resort. Customers must be warned that rejuvenating may work or even in some cases destroy the picture tube. I want to remind you as well, the symptoms you describe will over work the main board as well. This TV is not feasible for repair. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sanyo DS31590 31" TV
I have only a purple screen when i log on to laptop
Is it a purple that sort of fades into a reddish that will then disappear?
If that's the case, and it often is, you would need a new invertor for your LCD.
Let me know if you need further help.
Good luck!!
EJ Kudelka
Dec 26, 2010 | Toshiba Computers & Internet
I have a Panasonic Viera TH-50PX60U Plasma Picture Problem. The TV picture screen is showing up as purple. If i unplug the blue cable, the tv shows in black and white. If i plug in the cable, the...
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 24, 2017 | Televison & Video
Green and purple scrolling lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 27, 2017 | Samsung LN52A850 52 in. LCD HDTV
Emerson LCD TV won't stay on
http://electro-medical.blogspot.com/
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
Apr 02, 2017 | Televison & Video
The picture on my RCA P52926 projection tv is off.....there is a reddish shadow around the images....it all started when i fixed the focus because the picture was fuzzy....the focus is fine now it's just...
Sep 07, 2017 | Televison & Video
LG M2280D 22 in. LCD TV Logo
Computer Repairing
Computer Repairing
