Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
I hav toshiba roco 320gb hard drive which my computer dt recognice
  • 10406 Answers
SOURCE: I have 500GB Roco (Toshiba)
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 10, 2010
SOURCE: Portable Hard Drive will not respond / install
how many wattage had your computer? you need to upgrade your power supply.you need also to check your bios setup on usb port
Posted on Oct 03, 2008
paper bag
  • 72 Answers
SOURCE: My computer isn't recognizing my new Toshiba Roco
If it is new and has not worked at all, you should try using it on another computer that, if possible, has a different operating system. My first option would be to create a partition using a 3rd party partition creator.
Posted on Dec 26, 2009
lock123
  • 6831 Answers
SOURCE: Toshiba 320gb external drive is not detected by any laptop...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • 24 Answers
SOURCE: My portable Toshiba 320gb Hard
Unfortunately, this usually means you have some type of hardware problem. If you hear the drive spin up and just never connect to the computer, you are in better shape than most. The usual tricks to get around this are as follows:
  • Plug it into a different USB port, preferably on in a different part of the computer. The motherboard's USB hub might have flaked out.
  • Unplug it from the computer over night and try again later on. You may have tripped a thermal fuse on the USB line and sometimes they take a bit to reset.
  • If that fails, then remove the disk from the enclosure and hook it up to a machine with a free port. If you don't have one, I use Aprocorn DriveWire 3-in-one Disk interface to get on loose hard disks.
Unfortunately, there's really not much that can be done other than this. Good luck.
Posted on Feb 28, 2011
Toshiba hdd
As far as I know it is not possible to remove a password from a hard disk. In some cases a manufacturer may be able to help, however, for security reasons I'm not sure they would.
Mar 18, 2014 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Computer doesn't recognices HDD how can i reconfigure it
Either your HDD died or the connecting cable came loose. Open the HDD enclosure and check to make sure it's connected properly. Maybe reseat the drive.
Jun 29, 2012 | Toshiba Satellite 2545CDS Notebook
I have a 500gb roco toshiba external drive. the light is on but it won't read. i tried to change it's cable but still it won't work. how can i fix it?
try and listen to the drive when plugged in, if you hear a faint skipping noise. i suspect it is a fault internally on the reader.
if you have a reciept usually the manufacturer will exchange this. as a repair is very tricky!
Jan 23, 2012 | Toshiba Computers & Internet
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My computer do not recognize the toshiba roco HDD
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from external hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Toshiba 120GB USB 2.0 Portable External...
MY TOSHIBA HARD DISK MK3265GSX 320GB CANNOT DETECT TTO MY PC
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 13, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I have a Toshiba A45-S121 laptop. I upgraded my hard drive from a 40GB hard drive to a 320GB Western Digital. Loaded Windows XP and formated drive in FPTS format. The computer rebooted to the hard drive...
Best possible solution put back your 40GB and try to get an external casing for your 320GB to see if it works.And try windows on NTFS instead of FPTS, so reformat your 320GB and install the Windows XP again.
I hope this solution is helpful.
Sep 26, 2010 | Toshiba Satellite A45-S121 Notebook
My computer isn't recognizing my new Toshiba Roco 250 gb external hard drive
Dec 25, 2009 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
