Question about Samsung DMB28AFW Dishwasher
Displaying error code d02
Will start a programme and run for about 2 minutes then stops with error code d02 displaying
2 Suggested Answers
  • 6771 Answers
SOURCE: Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Posted on Jun 14, 2012
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
Our Siemens washer stopped spinning We have renewed brushes goes round now. But only turns one way then the other for one revolution We have tried different cycles but all the same is it the programer
First thing I would check if that timer which you are calling the programmer. If the programmer is not displaying an error code you properly have a bad timer given what your saying
Dec 19, 2015 | Siemens Washing Machines
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Our washer has been displaying the codes F21 and
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Nov 24, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
My front loading Kenmore is stopping in the middle of its cycle.
Aug 29, 2009 | Kenmore Washing Machines
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
Samsung DMB28AFW Dishwasher Logo
119 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
