Question about Gateway (4000274) Motherboard
Laptop won't turn on
I took my laptop in to get looked at because I was getting absolutely no power. The battery was fine and so was the ac adapter. They tell me its the mother board. Because I don't know a blessed thing about it I am not sure if I being told this is the problem so that I can replace it. They said that it would be cheaper to replace the whole laptop than to replace the mother board. What should I do?
  • piglet98 Oct 27, 2008
    I have no geek friends... Not techy geeks anyway...LOL ;-) I will try the second opinion first. Thanks so much for your help!
  • ronmero Nov 04, 2008
    I have the same problem. I found out that its the female part inside of the laptop that connects the motherboard to the ac adapter. There's a metal connector that leads into the motherboard from the female part, its broken, its soooo small that you can't find it. I, luckily found it by accident. I fixed it by soldering a bead connecting the broken pieces, if you're going to try be very careful. I have 2 gateway laptops and they both have that issue, I think gateway does it on purpose so that we could spend more money either trying to fix it or spending money to buy another laptop...ITS Bu!!Sh!T!!!!!
  • 35 Answers
If you know someone who has the same laptop, try testing your battery and adapter on that laptop just to make sure that they are working fine. If not, it might be a motherboard issue and replacing a laptop motherboard would cost a lot.
If you have a geek friend, ask him/her to use the multimeter to check that the power supply is delivering the correct voltage to the motherboard.
If you dont, try to get another opinion from another place to check if they say it's the same problem.
Posted on Oct 27, 2008
No power
Hello, If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems. 1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose Hope this helps
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Nov 10, 2012 | Toshiba Computers & Internet
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
My acer aspire 4330 won't power on?
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 26, 2011 | Acer Aspire 4730-4947 Notebook
My laptop won't charge. I only had it for two months.. I think it is the battery not the charger... Will the warrenty cover that?
Aug 17, 2011 | Sylvania G-Netbook
My Dell Inspiron Mini won't power up. When I push the "on" button, the light indicator flashes and goes off immediately.
Jul 21, 2011 | Dell Inspiron Mini 10 Notebook
My compaq c 581WM notebook pc won't start at all. A while ago it got pretty banged up but I got it fixed and it worked fine untill like 5 months after and from then it wouldn't charge or turn on...
Jul 21, 2011 | Compaq Computers & Internet
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
MY BATTERY WAS BLINKING, THEN IT WENT OUT.
Try to remove the battery and connect your laptop directly to the power adapter. We need to rule out that there is nothing wrong with the power of your laptop. Now, if the laptop turns on with just the power adapter. turn it off and place the battery. Make sure that the battery is charged. Then before turning on the laptop remove the power adapter. If the laptop won't turn on then there is something wrong with your battery you need to replace it.
Sep 22, 2009 | Computers & Internet
Gateway (4000274) Motherboard Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
