Question about Whirlpool LSQ8543J
Whirlpool washer blows fuse
Shortly after fill or rinse cycle starts the washer intermittently blows the breaker on the GFCI outlet it's plugged into. Have tried it on 2 different outlets and the behavior is the same... seems something inside the washer is shorting or overloading and causing the breaker to trip. Suggestions?
  • Matt Ouelette Feb 21, 2012
    Thanks for the response, but I think you may have missed the mark... On this Whirlpool Washer, the pump motor is the main motor, which shows no signs of trouble in the agitate or spin cycles, plus the pump only kicks on to drain the washer, not to fill it.
    See above
  • 4 Answers
The pump motor is starting to seize up. It is causing the motor to work harder which causes heating of electronics causing the fuse to blow
Posted on Feb 21, 2012
4 Suggested Answers
  • 85 Answers
SOURCE: My washer starts to run then trips the house breaker
Probably severe arcing on motor commutator due to worn out carbon brushes
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: The washer fills just fine, but when it starts to
I do home inspections, and this is a no-no! GFI devices are not real happy with inductive loads, such as motors and refrigerators. Generally during home inspections, we find that GFI's older than 10 yrs. have a 75% failure rate using a sophisticated tester. The 5 yr. old devices are at 50%. I'd replace that outlet with a single outlet, dedicated to the washer. If it's near a sink, then you're required to stick with the GFI. I'd just repalce it with a new one. Good Luck!!
Posted on Jun 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Calypso top load washing machine. No warning... no power. no breakers tripped! Outlest tested fine with another appliance.
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Fuse f21 what does it do. It keeps tripping out about every four weeks How can i fix this problem
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
Apr 16, 2017 | Washing Machines
Frigidaire Gallery Series front load washer and dryer. Last Friday the dryer started sparking and tripped the breaker. We had an appliance man come and he could not figure out what caused it.
Jan 11, 2017 | Frigidaire Washing Machines
Admiral washer. Did load of laundry, breaker tripped, and is still full of water. Reset breaker, and hear a small click after I pull knob to restart washer. Breaker trips. No leak, and outlet is good
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
May 22, 2015 | Admiral Washing Machines
How do i fix hoover vision hd washing machine that blew a house fuse then machine comes on will not start cycle ***
May 17, 2015 | Hoover Washing Machines
Main fuse in house went now machine will not start light under start button keeps flashing
May 17, 2015 | Washing Machines
Deawoo washing machin when start spin timer will triped elecricity
The washer tripped the breaker once and after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Mar 28, 2015 | Daewoo Dryers
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
I got 2 wascomat gen5 that trips breakers only on rinse cycle
WDD960 washer dryer trips the RCD when it is plugged in even when the machine is not running. Is the answer a new machine or can it be fixed
Feb 21, 2015 | Dryers
LG Tromm washer tripped breaker, now won't come on at all
Jan 06, 2014 | LG WM0642H Front Load
Washing Machines Logo
282 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
