Question about Dryers
Dryer does not start when pushing button on lnc7757a71 check breaker its ok.
Dryer will not turn on, Breaker ok
SOURCE: Kenmore 90 series model 110 60902990
Thanks for your ideas for the solution, but after I opened everything up, I discovered the belt broke...duh!! So when in doubt, just open it up and look!
Thanks,
bero
Posted on Oct 24, 2008
  • 1122 Answers
SOURCE: Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Posted on Apr 22, 2009
  • 1122 Answers
SOURCE: Dryer will not work. Makes buzzing sound when
locked up dryer motor,replace-mike
Posted on Jul 19, 2009
jsrock516
  • 5911 Answers
SOURCE: dryer won't start when i push the button,checked
If your model number is correct, all the heating circuits on your dryer are easily accessible from the back of the dryer. All you have to do is unplug the dyer and remove the back panel. Look for the Thermal Fuse. This will be a small plastic looking component with two wires attached to it. Its mounted on the blower fan housing on the left hand side of the dryer (as facing from the rear). Unplug the wires from the Thermal Fuse and take a resistance reading across the terminals. If good, it will read 0 ohms. If bad, you must replace it.
This component will blow in an overheat/over-current condition and must be replaced. Usually when this component fails, it fails for a reason. Check your blower fan housing for any clogs or obstructions that may be causing the dryer to run hot.
For clarification, refer to appliancepartspros.com for exploded view daigrams of your dryer. Just type in your model number and look under Section 3 for item 19 (part number AP3132867).
Something else to consider:
1. Does the dryer have multiple breakers? An electric dryer runs on 220VAC. Some home use two 110VAC breakers instead of one 220 breaker. Double check your power distribution and make sure you have the breaker(s) set properly.
2. Have you checked the voltage at the wall receptacle? Unplug the dryer and take a voltage reading across the two hot (left and right slots) terminals. If good, you should read 220-240VAC.
3. Have you verified the power cord is good? You can check the power cord by leaving the dryer unplugged and remove the back panel where the power cord is installed on the back of the dryer. This is called the terminal block. You can either perform continuity checks between the prongs on the cord to the terminals at the terminal block, or you can plug the cord back in and take a voltage reading across the RED and BLACK wires at the terminal block.
If good, you should read the same 220-240VAC that you read at the wall receptacle.
If continuity is good you will read 0 ohms resistance from the end of the power cord to the terminal block.
4. Have you verified the door switch? When you open the door is the drum light on? With the dryer plugged in, you should be able to open the dryer door and see the light on insode the drum. Toggling the door switch with your finger, this light should go out if the switch is making contact. If the switch is defective, the dryer will not run.
I hope I've given you enough items to consider. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 30, 2009
  • 496 Answers
SOURCE: I push the start button and the dryer does not do
There are probably several things to try... You've done the first of them by checking the breaker and plug at the unit.
One suggestion is that most all models have a safety switch that doesn't allow the unit to come on if the door is open. Just a check... you might trick the switch to see if the unit wants to come on when you press the start button.
I hope you get it narrowed down to the fix...
Posted on Aug 31, 2009
Go to push start button and nothing. Have check breaker. Still on. And how do you level the dryer? It's a model:TEDS840PQ0
Number 7 is the fuse. If your dryer has enough lint built up in it the dryer will overheat and melt this fuse. You need to clean it up. Now here is an example of a dryer with a fuse probo:
How it goes back together:
Sep 19, 2012 | Kenmore Dryers
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Dryer won't come on
check the door switch in the corner of the door
see if it broke off
Apr 23, 2009 | Kenmore Dryers
Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Problem with my GE dryer
  • turn your circuit breaker off then back on. sometimes the only one side of the dual 220v breaker will trip leaving you with a non functioning machine thats seems to have electricity going to it.
  • another thing to check is the door switch.
Jul 06, 2008 | GE DCSR483EA Electric Dryer
Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
May 26, 2008 | Amana ALE643RB Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
Top Dryers Experts
