Question about LG Refrigerators
LG elecrocool refridgerator not cooling
Stops cooling and when turned off for a few days and turned on will work for a few weeks
    Problem Solver:
  • 19 Answers
It is mos tlikely frosting up on the evaporator, this shows up as frost on the back wall of the freezer that means its not self defrosting, check the defrost system, defrost termination therms can go bad, and need replacement, defrost elements can short out, defrost board if it has one may be bad.
Posted on Mar 14, 2012
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Everything is out, we have it off, no water is draining. The freezer just stopped cooling, hence the refridgerator side stopped too. I just turned it on after 5 hours. The motor is running and so is the...
Could be that your self defrost mechanism is not working and unit is freezing up and not cooling. Till fixed just defrost overnight and turn on next day. It will run fine for a few days till it freezes up again.
Probably need to replace open heater element. Go to sears web site for part number and then purchase it for less money on ebay.
Sep 18, 2017 | Amana Side-By-Side Refrigerator 26 cu. ft....
Ge refridgerator model sts16abserww, stopped cooling, down at the compressor I hear a slight click then wait a few seconds and hear another click (NO buzz between clicks), then wait a few minutes and the...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Refrigerators
Freezer and fridge not cooling. if i unplu unit for one day and plug back in it works for two weeks and then stops cooling again. Aslo a lot of water leaks from bottom when i uplug it
You have a problem with the defrost system. It could be a few things defrost heater, thermostat, or defrost timer. It works for a few weeks then the evaporator coil is icing up (stops cooling) then you unplug and thaw it out(lots of water) Here is a link that should help Refrigerator not cooling
Click on the links in the troubleshooting and they will bring you to videos on repairing this.
Sep 20, 2010 | Maytag Refrigerators
Sudenly stops working everything in freezer thaws out and refridgerator goes warm,the lighhts are on and the fan inside the freezer is blowing warm air.if i unplug it and it sits for a few hours and then i...
The auto timer in your Fridge is faultly and is not defrosting in the eight hour cycle. There could also be any wire detached from corrosion inside/within the freezer compartment that gives wrong signals to the the thermostat. You will have to remove the inside cover to confirm.check the wires to the heater/ failure of the heater. In case you are not able to do the work have this in mind and look into what the technician responds. take an estimate and move on.Helpful? good day
Jul 02, 2010 | GE GSH25JFR Side by Side Refrigerator
Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
GE side by side refridgerator
you need to check the defrost heater with a omes meter,ge sxs are very bad about heater burnout and most must be replaced with a heavy duty one,let me know,thanks-mike
Jun 23, 2008 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
146 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
