Question about Lands Phones
Reprogram lg vs 690 from start - Lands Phones
After jump started my ktm 690 enduro 2013 model the tachometer is not working properly
Hi, Jaco if you jumped it off a running automobile you may have fried delicate circuitry the tachometer needed for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
KTM 690 tachometer stopped working
KTM 690 EFI Idiots Guide
KTM 690 Enduro EU 2013 Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 690 Enduro USA 2013 Owner Manual
Mar 07, 2017 | KTM 690 Enduro Motorcycles
SC 690
GAVD I2C
communica-tion
error
690-001: Y
690-002: M
690-003: C
690-004: K
Jul 15, 2014 | Ricoh Aficio 2232C Color Copier
Code to solution problem 690sc
SC 690 - GAVD IC2 communication error.
690-001 :Y
690-002:M
690-003:C
690-004:K
Possible cause:loose connection,defective BCU,defective LD controller board.
Turn the main switch OFF and ON,check the cable connection,replace the laser optics housing unit or replace the BCU board.
Feb 17, 2013 | Ricoh Aficio 2232C Color Copier
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
My fathom vs750 showing invalid battery id when iam switch it on after that it switching off, what can i do
I brought lg fathom vs 750 online its seller refurbished , after i install the battery , i start switch on the mobile first lg logo is showing on the display after that a sign of battery picture is showing on display with invalid battery id written on it , after that it stops , i mean switching off..pls advice me how to resolve this problem.
Jun 12, 2012 | LG Fathom VS750 Phone Verizon Wireless
How to reprogram lg kg300
You will need to have the software to be loaded which the legal copy is available with LG.
Hence I would suggest that you contact LG for sorting out your issues to reprogram.
Please click the link below:
LG phones
Jan 03, 2011 | LG KG300 Cellular Phone
We replaced an LCD screen on the lg versa.
you need to reprogram it because the broken lcd and the one you replaced have diffrent serial, reprogram the sofware.
Jun 23, 2010 | LG VX9600 Cell Phone
I sat on my remote and now it doesnt work is there a way to reprogram the remote?
Check if the remote is still transmitting. You can do this with a digital camera. Point the Remote at the camera's lens then start pressing buttons on the remote. If you see a blinking light from where the remote transmits on the digital camera's LCD screen, the remote is functioning properly.
If you do not see it transmitting, replace the batteries. If it still does not work, the only thing you can really do is get a new remote, there is no way to reprogram the LG remote. You can get a universal for for pretty cheap or you can contact LG to get the exact replacement remote for your TV to ensure it has all the functions needed.
Oct 09, 2009 | LG 42LG30 42 in. LCD HDTV
LG 8700 "downloading" error on startup
You may need to reprogram your phone. On Verizon you dial 228 then listen to prompts. They will finish and tell you it is complete. This should help you out. Good Luck.
Jul 06, 2009 | LG VX-8700 Cellular Phone
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
