Question about Canon PIXMA MX850 Multifunction Printer
Remove cyan ink from hands - Canon PIXMA MX850 Multifunction Printer
  • 669 Answers
Best thing I have found to remove ink from hand is rubbing alcohol. Follow up with some hand lotion, since the alcohol will dry your hands out.
Posted on Feb 22, 2012
Testimonial: "yes, will try, thank you"
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
Hi, I'm trying to print in b&w. The printer says " no cartridge" although all four of the cartridges are in. It says "open scanner cover, then reinstall ink". If I lift the cover it then says "install...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts, tighten the cartriges onto the slots.
Sep 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Cyan doesn't print
Have you had a paper jam recently? My only thought might be that a small piece of paper is stuck where the cyan cartridge prints.
Maybe get an air duster spray can, remove all inks and spray inside.
Aug 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The printer has ink in the chambers, but message keeps coming up
Ink sticks are blocked in the ink loader assembly.
Are using generic ink sticks "Media Sciences" perhaps?
Remove all ink sticks and reinstall.
Feb 24, 2009 | Xerox Phaser 8550DX Laser Printer
XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
Oct 29, 2008 | Xerox Phaser 8500/DN Printer
How to replace ink cartridge in canon pixma IP1800
make sure that the ink cartridge is in the docking posistion on far left hand side of printer. press down firmly on the cartridge and then slide it out.
Oct 06, 2008 | Universal Office Ink Tank Cartridge for...
HELP!!! Phaser 8500 Error 09.035.43:28534
That is a cyan ( blue) ink stick count failure.
Look in your ink loader. First just try opening and closing the lid.
Then look for gaps in the cyan sticks. Most likely one is broken, cracked or otherwise jamed in the slot.
If you have to remove them, take a screw and screw it into the ink stick then slide it up the chute and out, then reload.
Hopefully someone didnt try to add or cut up a stick from a differerent phaser.
Thats your problem. Just a stuck cyan ink stick.
Mar 24, 2008 | Xerox Phaser 8500/DN Printer
Canon PIXMA MX850 Multifunction Printer Logo
93 people viewed this question
old marine
old marine
