Question about Empire FAW-40 Heater
EMPIRE FAW-40 SSP PILOT WILL NOT STAY LIT
REPLACED Thermocoupler
4 Suggested Answers
  • 117 Answers
SOURCE: PILOT FOR EMPIRE WALL HEATER WONT STAY LIT. I HAVE
are you sure the problem is with the thermocouple? is the pilot sharp and blue? it is unconnon for the magnet in a gas valve to go bad but it does happen. place the thermocouple in the valve and with it in front of you heat it with a match or lighter for 30 sec. now try and light the pilot quickly. if it lights the the problem would be the pilot, if not then the valve. is this a milivolt system or hydrolic t stat.
Posted on Jan 29, 2011
  • 4736 Answers
SOURCE: uh1200-fsp---pilot lit main burners wont
If you installed the new thermocouple, you may have overtightened it. It should be installed finger tight and only a quarter turn more. If it's to tight it won't allow the gas valve to open to light the burners. Be sure to turn the gas off, before attempting to work on the unit.
Posted on Feb 02, 2011
  • 4736 Answers
SOURCE: Empire FAW-60-2-spp fan short cycles
From what you have described, it sounds as if the Fan Control Switch, ECS Part # R-1941, which works in conjunction with the Limit Control Switch (ECS Part # 912073) is failing and needs to be replaced. You can order these parts directly from Empire Comfort Systems. If you decide to replace these parts yourself, it will give you an opportunity to thoroughly clean the interior of the Wall Furnace, if you haven't already. If you need further information, contact Empire Comfort Systems, Technical Service @ 800-851-3153 Monday - Friday.
Hope this helped you to troubleshoot the problem. Please don't forget to rate my response. Thanks!
Posted on Mar 27, 2011
I replaced the thermocoupler and it still will not stay lit.
is the tip of thermocouple in the flame of the pilot.
where the thermocouple screws into the control valve you just tighten it hand tight and then 1/16 of a turn. or you might have damaged the magnet.
is the flame big enough on the pilot light as it might need the jet cleaned.
failing all that then the magnet in the controle valve where the thermocouple screws in has failed and needs replacing if your model will allow.
Sep 28, 2016 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
Pilot won't stay lit when button is released
Thermocoupler is dirty or needs replaced. The thermocoupler is the copper looking tube that runs along the pilot tube. The flame has to hit the thermocoupler to generate milivolts to open the gas valve
Dec 31, 2009 | Cozy (W352E) Heater
I HAVE MODEL GP30 WALL HEATER. I CAN LITE PILOT BUT WHEN I TURN CONTROL KNOB UP PILOT GOES OUT AND DOES NOT LITE HEATER
The thermocoupler is bad.Replace it,or if you can adjust it to where the thermocoupler is in the pilot flame.You know you have to hold the knob down for about 30 seconds or a minute,don`t you?If the flame will not touch the thermocoupler,it will not stay lit.You can cut a piece of copper tubing,or steel tubing to slidde over the old thermocoupler to make contact with the pilot flame,and it will work,if the thermocoupler is not in to bad of shape.
Oct 17, 2009 | Heating & Cooling
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Pilot wont stay lit
Check the thermocouple,Its is a flame senser.It will not stay lit if it is bad.
Oct 04, 2009 | Water Heaters
Cannot get my pilot to stay lit
Make sure the thermocoupler is about 1/4 in in the flame of pilot. If it persists, as you say it is, the thermocoupler is defefective. It's that bulb in the pilot flame. Good Luck, Ned
Sep 29, 2009 | Heating & Cooling
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
I replaced the thermocoupler still not staying lit.
I understand it that once the main burners go off, after the thermostat is satisfied (water heated) the pilot goes out too at the same time.
Make super sure the top of the t-couple is getting hit directly by the pilot flame. You may need to adjust the t-couples position, or even clean the pilot assemblies oriface. Double checking the connection of the coax cable at the gas valve would be a good idea too. tight but not super tight.
Nov 14, 2007 | Pitco Frialator SG14 Deep Fryer
Heating & Cooling Logo
51 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
