Question about Elite Home Security
How do I program a remote to open my All-O-Matic Sw-300
How do I program a new Liftmaster 371LM one button remote to open
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: My newly purchased home has
hi,
You have to oppen the motor control pannel. There will be circuit board inside it. In the circuit board you can see a Push button switch. It is the learn switch.
After powering ON press and release immediatly this learn switch. With in 30 seconds press and hold the button you wish to use until two click heard from the control board.
If you can sent me your email id through FixYa then i will sent the picture which shows the learn switch.
OK.
Posted on Aug 29, 2011
Where is the program button located on moore matic x150.
If you mean the Moore-o-matic X150 garage door opener, it doesn't have a program button. It has three adjustment screws: Up limit and Down limit are on the downward side of the opener, the Door Pressure adjustment is on the back of the opener (lower left relative to the door operator terminals).
The manual for the Moore-o-matic X150 is available online from Manuals Lib, https://www.manualslib.com/manual/977303/Moore-O-Matic-X125.html#product-X150 , and liftmaster.com, https://www.liftmaster.com/catalogresourcesv3/en-us/shared/files/tucmanuals/a8448mm.pdf .
I hope this helps.
Dec 03, 2017 | Cars & Trucks
My liftmaster HBW 1573 no longer operates the garage door
Try the programation with the central control of de wall
hold light boton then press de open botton (dont un unpress the light botton. Then put the control about 2 inch of the main control until its open or close the garage door.
Let me now if it work.
regards
Aug 24, 2012 | Sears Craftsman LiftMaster Chamberlain...
My newly purchased home has a Beninca MS4 automatic gate opener but came with only one remote control (Liftmaster 371LM remote). I purchased two additional 371LM remotes online but do not know how to...
hi,
OK.
Aug 29, 2011 | Elite Sl 3000 Ul Sliding Gate Operator
I just purchased Liftmaster 971LM for my 139.53975srt1 Sears 1/2hp garage door opener. It will not program. I have only one working remote that was recycled from my father's unit - it says craftsman...
If the recycled remote is Security + there is no logical reason the new units should not work. If the old remote is a different technology and there have been changes to the opener or a different receiver that could be the problem.
Aug 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 371LM has stopped working. Do I need to "reset" it? If so, how do I do that? My other remote, which is older is working fine. Thanks!
Tries clean the battery terminal + - of the remote out for rust and moister out with a rag with some WD40 and used some rubbing alchahol in a rag clean it out and wait 20 for it to dries and put in a new set of battery.The remote have a great chances to work again,if not the remote probally have a dead CPU chip,it is garbage now happen to remotes devices all the times.
Aug 11, 2011 | liftmaster 371 Remote Transmitter
We have a Liftmaster garage door opener. I bought a new remote control for it - a Liftmaster security plus. I have tried to program it by pressing the button on the garage door opener, then pressing the...
YOU NEED TO MAKE SURE YOUR REMOTE IS THE SAME FREQUENCY AS THE EXISTING UNITS.
IF YOU LOOK ON THE BACK OF THE REMOTE THERE SHOULD BE A FREQ# IF THEY ARE NOT THE SAME YOU NEED TO EXCHANGE THE REMOTE.
HOPE THIS HELPS
Mar 26, 2011 | liftmaster Chamberlain Garage Door Opener...
Liftmaster Model 51 for 315 needs replaced. Does
This may help.
If you look on the back of the motor head, where the terminal strip is located, you will either find a set of numbered switches (1 through 9) with +, 0, - settings, or a colored square button. If you have the numbered switches, you want the 61LM model transmitter. If, instead, you have a colored, square button, check to see what color the indicator light, adjacent to this button, emits when it is pressed. If the indicator light is the color green, you want the model 81LM remote transmitter, if the indicator light is an amber color, you want the model 971LM transmitter.
Feb 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Home Security Logo
1,725 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
