Question about Gestetner Copier
Scan multiple pages to one file on gestetner 6002
I need to scan 7 pages but need them to show up as one file.
  • 3 more comments
  • avetos Oct 27, 2008
    Gestetner is maker. Model is 6002
    yes, i can scan one to file just fine. When I use doc feeder, it scans all 7 pages but puts them in file as 7 separate scans
    thank you!!!!!
  • Mike S
    Mike S May 11, 2010
    Network scanning directly to e-mail or to file is an option on this machine?
    Is it enabled?
    Can you scan 1 page to a file.
    If so using the Doc Feeder should scan 7 pages..
  • Mike S
    Mike S May 11, 2010
    What is the machine model, and who makes it?
    A document feeder will usually accomplish this
    Sharp machines, have a thing called "read end" when a scan is made, you put the next page on the glass to scan, at the end of the multi pages, you choose read end, and that will end the complete scan.
    Not knowing your machine model and type I cant really help you here.
  • 3 Answers
I apologize but this is a little to tricky to explain here....
below are guides and information on how to set up and operate a Gestetner machine,
which will help you to sort out every thing..
This is the Gestetner Site to download manuals, user guides..
http://www.gestetnerusa.com/SupportDocumentation.html?OpenForm&zone=ZIDTDIE-54FRT7GE51&NavExpand=0
This is the Scanning Guide
http://www.gestetnerusa.com/manuals/savin/SavGestOpManuals.nsf/(All)/GX60027502ScannerReferenceScannerReference.html/$file/Scanner%20Reference.pdf
Posted on Oct 27, 2008
Canon mx410 how to scan multiple pages into one document
What you need to do is select the file type as .png instead of the default .jpg. A .png file will create one file with multiple pages.
Good Luck
Mark
Aug 31, 2014 | Canon Pixma MX410 All-In-One Printer
Tip
Scan multi-paged document and create a single PDF document
1. You need to install a PDF printer driver on your computer first.
There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
To download CutePDF printer driver (freeware) click on this link :-
http://www.cutepdf.com/
2. Using your computer SCAN the first page then click on File - Save the image as a jpg file Eg. image1.jpg
4. Repeat step 3 for the other pages.
5. Close the scanner when finished scaning.
6. Open a Word document then place each image file on a new page in the Word document
7. Save the Word document if you require but not needed.
8. Click on File - Print then select CutePDF printer (or your PDF printer driver) and save the PDF file. This PDF file will contain the multiple pages of the scanned pages.
on Jul 07, 2011 | Computers & Internet
Scan to file on DSc525
The smb version on windows 7 is new than the one on XP. You will need a firmware upgrade.
Jul 29, 2013 | Gestetner DSc525 All-In-One Laser Printer
How to scan multiple pages in one pdf in hp 5300c scanner
To do this will take a few steps.
1. You need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
2. Scan the first page then click on File - Save the image as a jpg file Eg. image1.jpg
5. Close the scanner when finished scanning.
7. Save the Word document (not necessary).
Jul 07, 2011 | HP ScanJet 5300C Flatbed Scanner
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Can't scan more than one page under one file
you need to check for updated drivers from the manufacturer's website as the "old" drivers may not be completely compatible with windows 7.
this often happens when changing operating system to a newer OS
Jun 19, 2010 | Epson Perfection V500 Flatbed Scanner
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
Can't scan multiple pages into single document - reinstalled drivers but still can't - used to be able to. How do I fix this?
http://files.support.epson.com/htmldocs/…
I think this says you need Professional Mode rather than Full Auto Mode.
Under File Save Settings in the Professional Mode, you should see buttons for Add Page / Edit Page / Safe File.
Basically, you keep adding pages then finish.
If you already have multiple .pdf files that you wish to combine, Acrobat Professional (not READER) can do that.
Good luck,
- CarlD
I copied the text but I think you won't be able to see the images here:
4. Select PDF as the file type setting. The current Paper Size, Orientation, Margin, and Compression setting are displayed below it.
5. If you need to change any of the current PDF settings, click the Options button. You see the EPSON PDF Plug-in Settings window:
Select the settings that match your document and click OK. You return to the File Save Settings window.
6. When you are finished selecting file settings, click OK. Epson Scan scans your page and displays this window:
7. If you are scanning only one document page, or you don’t need to edit your pages, click Save File and go to step 10.
If you are scanning multiple pages, click Add page and replace the first page on the document table with the second page and click Scan. Repeat this step for each page in your document. When you are finished, click Edit page and go to step 8.
8. You see the Editing Page window displaying thumbnail images of each scanned page:
If you want to include all the document pages in your PDF file as they currently look, go to step 9.
If you want to delete some of the pages, click the odd pages or even pages icons, or click the individual pages you want to delete. Then click the delete icon to delete them.
If you want to rotate pages, click the pages or use the odd pages, even pages, or all pages icon to select the pages. Then click the left or right rotate icon to rotate them.
Note:
The delete icon is not available when all document pages are selected.
9. When you have finished editing your document pages, click OK. Your document is saved in a PDF file in the location you selected and you return to the EPSON Scan window.
10. Click Close to exit Epson Scan. Source(s): http://files.support.epson.com/htmldocs/…
Aug 22, 2009 | Epson CX8400 All-In-One InkJet Printer
Gestetner 6002?
you can down load a user manual for the machine at www.gestetner.co.za
Jul 29, 2008 | Gestetner Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
285 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
ap-it
ap-it
jmartin50
Level 1 Expert
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
