SOURCE: Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
SOURCE: protron pltv3250 32 in. lcd, no power, no lights, nothing
I service these power supplies. For more info write to [email protected]
SOURCE: TV wil not turn on at all
My Protron PLTV - 3250 just went out yesterday. By this I mean it turned on and went out in a few minutes. I left it off and today it completely died. I opened it up because I always think I can repair things. So what I found is a burn mark on the curcuit board of the power supply which is located inside the tv. On the other side of the burn mark is a (zener diode), this diode is burned out and therefore the power supply is not working. I am going to Radio Shack tomorrow Monday Aug. 31, 2009. The diode is very tiny but should be easy to replace with a sauder gun because this diode has place holders to hold the tiny diode in. If this does not work at the top of this page is a link that says power supplies for your tv for sale. I am going to check it out. Anyway just so you all who know about computers= the tv power supply is similar to the power supply on a computer. Just like a computer power supply comes in a case that you install into your computer and then you just connect the connectors to your motherboard and drives. Well in the tv the power supply is stand alone also, you can disconnect the wire connections in the tv and replace the power supply. If you notice the power cable to your tv is the same as a computer power cable, so the power supply in the tv is much the same as a computer power supply. I hope this helps you.
Comments:
Aug 31, 2009- Hey the link TODDTHETVMD is posting has a picture of the Protron PLTV - 3250 power supply. It looks exactly like that in my tv. Buy it. All you have to do is remove screws and and cables and put them back and you are all good to go. It is as easy as replacing parts and components in your computer. Thanks TODDTHETVMD.
SOURCE: tv won't turn on
Ur power supply board is dead.Replaced the power board will solved this problems.Tries websites like Sopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
