Question about Onkyo TX-NR801 Receiver
I have 6omh,max power:500w x2 sub woofer,so i want to use this speaker,what kind of amplifier is suitably for this speaker
3 Suggested Answers
  • 151 Answers
SOURCE: 8omh reciever and 6omh speaker
HI,in the speaker set up menu on your amp there should be a 6ohm setting but if not don,t worry as it won,t cause any problems.You will have to set the levels for your speakers so they match each other to keep sound right.
HOPE THIS HELPS.
CABLE GUY.
Posted on Aug 05, 2008
dunnbiker
  • 8546 Answers
SOURCE: I have an onkyo reciver and 7.1 speaker system.
I assume you mean the subwoofer remains silent during the test. Perhaps the subwoofer is where we should be looking.
If you jack it into one or both of the Tape Out connectors and play some music with substantial low bass, does it make any sound? This would at least prove it is alive.
Posted on Dec 14, 2010
How to splice a sub-woofer to speakers
Normally the sub woofer is driven by a separate amplifier, unless the main speakers, such as in a pro audio setup have a special LF out set of terminals on the back of the speaker cabinet, in this case there is a hi powered low pass filter, fitted in side the speaker to route the LF energy to a sub woofer. Else you need a line lever LF signal spliter and a power amplifier to connect a sub woofer.
Jan 26, 2017 | Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
Two questions. 1) can my amplifier over-power this sub; kicker L7 15 inch dual voice coil 1,000 watts RMS wired for 2 ohms? 2) is my amp too small for this sub-woofer? thank you for your time.
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
Apr 08, 2011 | Kenwood KAC-9103D Car Audio Amplifier
Can i power 2 12 subs a rockford punch z and a xplode with this amp i found all this **** in my garage and i need to know if it will power all this
First of all. Using two different kinds of sub woofers, is not an option, as these two sub woofers have different specifications and you should never mix sub woofers. Now the better choice from the 2, would probably be the Rockford. (cant be sure without knowing the models, power handling is also a factor in how well either of the sub woofers will play, but Rockford as a rule makes better sub woofers than Sony does) In my opinion, both the sub woofers deserve a better amplifier than what Boss has to offer. However to connect either of these sub woofers, you would need to determine how many voice coils it has and how many OHM the voice coil/s are. If it is a DVC (dual voice coil) and each voice coil is 4 OHM or 2 OHM, then you can connect one voice coil to one channel of the amplifier and the other voice coil to the other channel of the amplifier. If it is a DVC 2OHM you can also connect it wired in Series/Series to give a 4OHM load and should be connected to the BRIDGE dedicated speaker outputs of your amplifier. If it is a SVC (single voice coil) and it is 4 OHM, then you can connect the sub woofer to the designated speaker outputs of your amplifier that states BRIDGE. DO NOT run the amplifier in BRIDGE mode at 2 OHM as this will probably damage the amplifier. dreamsystems
Feb 18, 2011 | Boss Blade BL700 2-Channel Amp - 300W...
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Hardly used this amplifier in conjunction with a Panasonic TV Quintrix
just about any decent amp with surround sound capabilities will solve your problems there !!! all you need is male - male phono jacks and your away
Sep 11, 2008 | Audio Players & Recorders
Home theater system protection kicks out
Nice write-up.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
On page 6 of the manual it states you should use a powered subwoofer and the unit provides a sub output on the rear panel for it. The message from the amp kicking out is that you're not going to get away with your workaround.
I would advise you to purchase a nice amplifier (2-channel bridgeable or single channel) for the subwoofer. That way you'd be sending only LFE signals and your receiver has provisions for adjusting its volume relative to the rest of the channels. I use a nice 5-channel Carver for my 3 subs and both Rear Surrounds.
On eBay I see what I would get if I were you - a Carver M-200T (120W x2; 300W bridged). I have one.
http://cgi.ebay.com/Carver-Magnetic-Field-Power-Amplifier-M-200t-120WPC-Amp_W0QQitemZ200327110781QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200327110781&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
Mar 02, 2008 | Sherwood RD-6500 Receiver
Onkyo TX-NR801 Receiver Logo
27 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
