Question about Sony Handycam HDR-XR520 High Definition Camcorder
What's your problem?HDR XR520 LCD DISPLAY SCREEN REPAIR BLOCK
The Display is cracked, but it is still working. Problen is, the screen is giong darker.
  • gruenfeld
    gruenfeld Feb 21, 2012
    I need to buy an display from an other crashed Xr 520
  • gruenfeld
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Posted on Sep 22, 2009
Davidivory1
  • 338 Answers
SOURCE: does the sony handycam HDR XR520 camera have pass
Not many cameras will use all formats in them no, but once your movie is on your hard-drive of the PC you can copy the film to any other media.
Posted on Jun 24, 2010
A video backup from Sony Handycam HDR XR520 to a PC running Windows 8.1 fails as soon as it is connected via the USB to the PC. Its back-up program displays a message "Unable to retrieve the manageme
Repar database file.this is a function inside the camera menu. If database is corrupt because of erased files,like photos or videos deleted from a pc, then at backing up is trying to locate lost files. Remeber. Repair data base files. Or "repair DBF" inside menu.
Oct 02, 2014 | Sony Handycam HDR-XR520 High Definition...
Internally cracked LCD display
If the screen is cracked, it will branch out like a spider's web with black margins showing. The whole LCD display will need to be replaced, go to www.ebay.com Type make and model of laptop, refine search to screen and check price listings.
Jul 21, 2012 | Acer Aspire One Netbook 8.9" Notebook
What's your problem?lcd 32 in tv screen cracked but i can't feel the crack
This is the end of the set===screen is called a display panel and if available will cost more than a new set just for the part.
May 24, 2012 | Envision L32W761 32 in. LCD TV
I need to replace my lcd screen because the camera was dropped and it now has a cracked display. Can I do this myself or best to send it in. If DIY I will need diagram to take the display apart.
Unfortunately, it is not very easy to get to the screws to open the LCD display. It usually involves taking the top, front, and side case off to get to those 2 little screws on the side that open your display. LOTS of flex cables (easily torn) and a big capacitor used for your flash that can bite you pretty hard. I would suggest sending it in to Sony directly or find a local camcorder repair shop.
Sony factory repair: https://eservice.sony.com/webrma/web/index.do says $431.00 flat rate, but that does not apply to units requiring replacement of display devices.
You might be able to get off a little cheaper if you can find a repair shop that has a good used LCD that can go in there. We try and save our customers money by giving them the option of new or used (if we have one) parts when it comes to displays or case parts.
Hopes this has helped you.
www.austintelstarservices.com
Jul 27, 2011 | Sony HDR-XR500V AVCHD Camcorder
My Sony HDR-SR12 touch screen don't show anything when i open the camera. when i pust it a little in front of the camera it start to display, but otherwise it don't. I think there is a contact...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jul 15, 2011 | Sony HDR-SR12 HDD Camcorder
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I'm doing mine myself. Results to follow, maybe, if I remember to post following the repair.
I have a Sony A300. When I turn on the live view screen, I only see a bunch of vertical lines on the screen and cannot see anything that I try to display (ie. menu, display, prior photo's, or the...
Sorry to say your LCD screen is cracked, it happens a lot with the Sony DSLR-A300 and A350. The solution is to remove the cracked LCD and replace it with a new one. The repair isn't that difficult, but you have to be careful removing the LCD or you will break a latch holds two FPC cables together and then will have to replace yet another part that takes MUCH more labor.
I did a Google search for "sony a300 lcd repair" and at #2 I saw an online digital camera repair shop that has done tons of this repair over the last few years.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Sony Alpha DSLR-A330 Digital Camera
My i-mate mobile his display not working, i want to new display set my mobile. so plz, help me,
If the display is not working you may check your Mobile LCD screen is broken or cracked and on the outside is completely intact but the inside looks like a smashed pain glass or if you can`t see anything on the screen try visiting mobile repair center. You may try this link for them to check your mobile.
http://mobile-repairs-service.com/repair/lcd-display-problems/i-mate-sp5/10/879.html
Mar 16, 2011 | i-mate JAQ Pocket PC
I dropped my SONY HDR-SR1 Handycam with LCD open. LCD cracked in 3 lines. Display 75% visible. Touch screen still works. Over time display now 50% black 50% visible. I have downloaded the Service...
LCD's can be replaced althhough it is really not a user serviceable problem and will usually need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 26, 2010 | Sony Handycam HDR-SR1 HD Camcorder
The lcd screen is almost black/ very dark, but i still see that it works. it looks like the light is out. sony hdr hc1
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Aug 07, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Sony Handycam HDR-XR520 High Definition Camcorder Logo
53 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
