Question about Sansui CDVD1300W 13 in. TV/DVD Combo
Owners Manual and Remote Control
I want to switch from cable to analog. I have sound only when I use the DVD player.
My techwood won't play sound and the colour is completely wrong. How do I fix this?!
please see the chart troubleshooting. and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Gemini 1 Device Universal Television...
TV code number
0056 is the code for the LG TV.
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
IrishDruid
May 13, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVD and the new converter box
Lorrie47, Need more info to help you. YRU trying to connect any A//V cables to the HDConverterbox to your DVD player? Can you plug the DVD player into the widescreen HDTVset or do you have old NTSC TV set like I do? I haven't even been to Circuit City, Sam's Club, or BestBuy to see what kinds of connectors are on those HD Tuner/Converter Boxes. Is the converter box u have equipted w/yellow(video), red(right), White(left) analog signal in's and out's? If the new HDTVconverter box has BASEBAND in's and out's then the installation/owners manual should have directions for their proper use. In any case you need to be more specific on what you are trying to accomplish. Tell me, does TV set stay on channel 3 , and never ever changed to chan22 or 51 or 8. Its always set to ch3?
Is it possible that maybe TV set has baseband (yellow,red,white) in's and out's on rear of cabinet? Now here are some rules to follow. Outputs must go to inputs. and colors must match. I assume that the HDTV tuner/converter box has a infrared remote control to do channel change and vol/up/dn and possiblly other things like switching of sources. does the manual say anything about AUX A/V inputs that can be used? Hpoe this has been of some use to U. I'm Louie12fix can be emailed @ this:
lmistyrel @ aol.com north of Chicago
Jan 12, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Nov 28, 2008 | Toshiba Televison & Video
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Jan 20, 2008 | Onkyo DV-SP800 DVD Player
Eas tv model et427e
Using your TV remote (not the cable remote) use the input/select button to swtich to videe 2 or ? ; this should allow DVD to work/ when done use remote input/select button and switch back to video
Dec 23, 2007 | Televison & Video
Trouble with remote
This happened to me twice before, I forgot the solution but it's in the owners manual, if you dont have it, go view it on pansonic's site.
Oct 14, 2007 | Panasonic DMR-E85H DVD Recorder
Yamaha RX-V657 Zone 2
Suggestion by clarkent22
I called and spoke with Yamaha support staff (Chuck) who was very helpful. I was able to get my issue resolved hopefully this works for you too.
Couple of solutions:
1) Go into the Menu setting (Manual SetUp/Speaker Set) and make sure that you do not have Presence Speakers or Suround Back Speakers
2) Also in the Menu settings (Manual SetUp/Options/Multi Zone Settings) make sure that your Zone 2 Amplifier is set to "Int" (assuming you are not using external amp
3) Zone 2 can only accept an analog signal (not digital)... so there are two steps to this one. First, make sure that you either run only analog, or if you run digital and analog then you need to select "Analog Input" on the front of the unit. If yours was working earlier, my guess is that your input settings got switched to digital (or auto) You need to have analog set up for each specific external source (DVD, Cable/DTS, etc)....
4) This model receiver will only let you control Zone 2 with the remote control. You can power it on the receiver unit. But to select your source you have to press the Amp button, then the ** button. Then you control Zone 2 and you can toggle sources and adjust volume. (Check your owners manual for programing remote for zone 2.. think I pressed the "code" button and then 2999.)
Hope this helps... it worked for me If not call Yamaha they were very helpful.
Oct 13, 2007 | Yamaha RX-V657 Receiver
Bizzare Color Problem
I normally find that the DVD is either in the progressive scan or interlaced mode. If the DVD is in analog inputs (video inputs), then, it should be in the interlaced mode. If the DVD is in the component input, then, it should be set to the progresive mode. On older DVDs, the switch to turn it to the proper mode is on the back or bottom of the DVD. Newer units are on the remote that says progressive or on the menu of the DVD. The owners manual should have instructions on how to change it.
Sep 01, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sansui CDVD1300W 13 in. TV/DVD Combo Logo
35 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
