Question about Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
Epson TM-U200b gives 2 flashes of the "Error" Led. Will not print test page on startup, just two (2) Flashes, pause & two (2) flashes. What does this error indicate and can you direct me to a website that gives a description of all the error codes for this printer?
Thanks,
Gerald Swank
  • 3 Answers
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Posted on Aug 14, 2012
Error light blink
Posted on Aug 23, 2010
3 Suggested Answers
SOURCE: RE: Epson TM-U200 printer with error (2 Flashes)
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Posted on Dec 04, 2008
masterminds
  • 51 Answers
programmer can be used. example Makefile is included for LED flashing sample project in ..... but gives no such newsgroup error after specify the title. ...... Uses two-wire serial data communication through printer port. ...... The simple emitter-follower does not have a gain of exactly one,
Posted on May 27, 2009
How I print a config sheet
To print the test page hold the pause button of printer and on the printer. dont leave pause button till the printing .
Sep 25, 2014 | Epson TM-U325D-940 DOT MATRIX RECEIPT &...
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Epson tm t81 can not gives test print and shows state is invalid
If epson tmt 81 is not printing test page then check for dip switch below the printer and also reinstall the printer driver & configure the port properly
Oct 02, 2013 | Epson TM-T88III Thermal Printer
Paper not feeding
Hi
Open it up and check the installation of the labels.Make sure the roll is correctly fitted.
Turn it off and on.Solved?
Turn the printer off .
Press and hold the power button and then turn printer on.
Release the button.
The printer will print a test page.
Try feeding now.
Mar 01, 2012 | Epson TM U200B Matrix Label Printer
Epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
Aug 31, 2009 | Epson TM-T88IV Thermal Printer -...
Error light on the printer flashes twice every couple of seconds
check for the event log if it helps you find the reason
Jul 07, 2009 | Epson TM-U220 Matrix Printer
May 27, 2009 | Epson TM-U220 Matrix Printer
Oct 27, 2008 | Epson TM-U220 Matrix Printer
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
13,063 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
