Question about Delta & Single Handle Shower Faucet
Bath tub handle is loose and I need to know how to tighten it.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Remove temp handle and tighten screw a little
Posted on Mar 06, 2013
2 Suggested Answers
  • 129 Answers
SOURCE: bath tub water faucet leaks. It is a single
You will have to replace spring ang washers behinde valve cartridge.
Posted on Oct 24, 2009
For a tub overflow washer (Part# PPC826-3) where should the "thick end" go - top or the bottom? Is pasting a little silicone recommended on it so that it has a better seal after I tighten the screw?
The thicker end goes up because of the sloped end of the bathtub. You should not need to apply any sealant - the gasket is compressed as the screw is tightened.
Dec 06, 2016 | Plumbing
My shower/tub diverter lever is loose. How do I tighten it?
should have allen screw on bottom of spout...or just turn clockwise mite have an adapter but more likely to have allen screw to tighten spout..
Nov 22, 2010 | Danze & Plymouth& Single Handle Tub &...
Installed bath 3 handle unit. hot handle is stiff and hard to turn, shower diverter is loose. How can I loosen the one and tighten the other? I'm sure it's probably the same adjustment
The handle adapters can be tightened by turning them clockwise and loosened by turning them counterclockwise. If the faucet manifold may need to be lined up parallel behind the wall and moved forward as well. Here is the parts breakdown for your faucet,
Sep 05, 2010 | American Standard Hampton 7225.733.002...
Please tell me how to tighten the off/on handle. It is loose and I can't figure out how to take it off or tighten it. This unit was installed about 3 1/2 years ago. Thank you very much. George
There is an Allen "screw" which is threaded in from the underside of the handle.
Simply tightening this screw 'should' tighten things up.
If that doesn't work, perhaps the Allen screw needs to be replaced.
If you have the Allen wrench to fit, you don't even have to turn off the water supply, just turn the handle up and let the water flow for the time it takes to snug it up.
Aug 22, 2010 | Moen T2529 Monticello Single Handle...
Loose lever
pop cap off and remove screw,pull handle,now lift up on cartridge ,then position handle assembly on,make sure you hook around groove and set down.tighten up if it's a newer model,it will be a hex screw , but similar process
Apr 25, 2010 | Moen & One Handle Tub & Shower Faucet
We have installed a new tub faucet. When the lever is pulled to allow the shower to work, the faucet sprays water.
tighten valve stem seal loose remove handle and cover the nut on shaft tighten a little at a time to much and could bind up lever
Mar 22, 2010 | Moen & One Handle Tub & Shower Faucet
Faucet sounds like a fog horn
It sounds like the faucet washer has come loose. Pull out the valve and replace the washer or just tighten the screw.
Please rate if this helps-
Mar 27, 2009 | American Standard Hampton Two-Handle...
Leaky Faucet
You likely need to replace the Moen cartridge. There are clear instructions on how to proceed that come with the new cartridge.
Mar 14, 2009 | Moen & One Handle Tub & Shower Faucet
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Delta & Single Handle Shower Faucet  Logo
133 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
