Question about HEWLETT-PACKARD Computers & Internet
Hp g72-b50us laptop boots with lights and fan get to splash screen then shuts off???
  • 406 Answers
SOURCE: Dell B130 Laptop Boot Problem
if battery is new and functioning properly(battery) please boot in safe mode by pressing F8 during os starup. and logon as an administrator.
if nothing works out try reinstalling operating system it will solve the problem else update me the ststus.
Posted on Feb 26, 2008
  • 26 Answers
SOURCE: Loud Noise on laptop when booting
Most likely it is the POST throttling up the fan to 100% during boot up. Then it switches over to ACPI(?) power manangement and Windows manages your fan speed to extend battery life.
Suggestions:
Go to Dell Support Site https://support.dell.com/support/supportrequests/create.aspx?c=us&cs=19&l=en&s=dhs
Download the latest BIOS updates and run it.
If it continues, try a can of compressed air, and breifly blow out any debris from the system fan. Bits of paper and critter-fur can get sucked up into the system.
Posted on May 15, 2009
lserni
  • 466 Answers
SOURCE: Laptop won't boot. No splash screen. Crash
Take out any USB device from the PC when rebooting: some BIOSes will incorrectly try to boot off them.
If that doesn't work, enter the BIOS Setup (F2 or Del key at boot) and find the Boot Devices menu, confirm that the highest-priority one is "Internal HDD" (or the name of your internal hard disk).
Posted on Nov 07, 2009
SOURCE: Sony Vaio laptop vgn-fs640-w problems
That happenedto me one time but i pressed the either the S1 or S2 button right bellow the speakers and the screen came back on.
Reply if this works for you, if not... Im sorry.
Posted on Aug 06, 2010
  • 1335 Answers
SOURCE: I have an HP G72
The fan is not rotating up to specifications and is not cooling the system as required. You should have the fan replaced befoe you damage components on the motherboard. If you do not replace the fan, you will end up with a very expensive problem.
It also sounds like you are still under warrantee and should have it serviced by HP or an authorized service center.as soon as possible.
Let me know if you have any other questions.
Posted on Mar 06, 2011
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
My HP G72 17'' shuts down about once a day
Is it overheating? Does it shut down when left unattended? Clean fan and vents. Improve air flow through laptop. Change power settings/Advanced Power Settings to High Performance and change Hibernate/sleep to never.
Dec 05, 2012 | HEWLETT-PACKARD G72260US Notebook
Hp g72-227wm has a broken lcd screen i have a hp compaq le1711 vga flat screen hooked to my lap top it was doing fine i log off out of windows and shut down the pc when i turn it back on the flat screen...
Check monitor is set to correct input (VGA, DVI, HDMI) if it goes to sleep instantly.
Otherwise screen resolution is set too high. Boot into safe mode by pressing F8 during boot. Login and lower screen resolution.
Oct 03, 2012 | Computers & Internet
HP G72-261US Notebook heats up
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 07, 2012 | HP Computers & Internet
HP G72-261US Notebook PC heats up
Apr 07, 2012 | HEWLETT-PACKARD HP G72261US Notebook
There are many thin horizonal lines covering my computer, how do i fix this problem or get them off ?
First, try to check if this is a problem coming from just the settings of your desktop. Right click on a blank space on your desktop and click on Personalize. Choose any other desktop background and see if this will make the lines disappear.
If this won't work, then the problem lies on the video card or your screen itself. they need to be replaced.
Hope this helps.
Jul 02, 2011 | HEWLETT-PACKARD Hewlett Packard HP...
The motherboard controls the fan speed - and laptops often turn it off entirely when it is not needed. This sounds like a motherboard issue where an internal trace is broken and sometimes it makes contact, other times not. There's probably nothing you can do except replace the motherboard.
Jan 18, 2009 | Computers & Internet
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Computers & Internet Logo
78 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
