Question about Xerox DocuColor 12 Printer
ENVELOPE PRINTING can you print DL(220mmx11mm) envelopes on DC12 copier?
  • 62 Answers
'fraid not mate
Posted on Nov 19, 2008
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
What is the maximum weight of paper can you put in the printer?
Plain paper (60 to 90 g/m2), heavy paper (91 to 163 g/m2), envelope
(Envelope DL, Envelope COM10, Envelope C5, Envelope
Monarch, Envelope B5), label sheet, transparency ((Black and white
printing only)
Jun 10, 2010 | HP Color LaserJet 2600n Printer
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
DX4700 printer. How to print DL size envelopes?
Hi if you want to print different size envelopes doing it with word I have found is the best way. Start word then click on print envelope or label this case you want a envelope. THen there is aan icon to click on to set up the printer preferences so you can pick the size envelope you want. The way its fed into the printer etc, a lot of settings including printing colour, font size and even printing the senders address on the top left corner of the envelope. hope this helps you a bit. Cheers, Phillip
Aug 30, 2009 | Office Equipment & Supplies
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Jul 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing Envelopes
Be sure you have set the PRNIT PREFFERENCES on your program that you are using to print the envelope to accept a #10 envelope and not 8.5x11 paper, you ALSO must set the PRINTER PREFERNECE to MANUAL FEED and not automatic so it won't look to the paper tray.
//CowboysFanZ
Mar 28, 2008 | Dell 3100cn Laser Printer
Printing envelopes
did you put these envelopes right way (portrait/landscape) also you have to change in printer menu paper source paper type from plain paper to envelope.
Mar 24, 2008 | Konica Minolta magicolor 5430 DL Laser...
Xerox DocuColor 12 Printer Logo
130 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
