Question about BenQ MS510 3D Projector
I have recently purchased a benq m2510 projector. i'm hooking it up to my x-box360 and to my bose speakers.... sound keeps cutting out. checked the hdmi and teh rca cables and even hooked it up to
SOURCE: how to hook up BenQ PB6100 Digital Projector to a lap top?
Use a standard "video cable" that is used to connect a desktop to a monitor. Your lap-top will also have a similar video out - this is a blue colored outlet jack on your ap-top with three rows of 5-pin holes. The BenQ also has a similar blue receptor jack almost next to the place where you plug in the mains power cable on the rear of the unit.
Posted on Dec 30, 2008
projdoc
  • 2237 Answers
SOURCE: I have a DLP Benq projector (not sure the model
go into the menu and reset the settings to factory default. after that, select computer again and see if it recognizes it. you may need to change the resolution to match the laptop.
Posted on Sep 09, 2009
projdoc
  • 2237 Answers
SOURCE: no pic pleas help .
reset the settings to factory default on the projector. make sure the resolution matches.
Posted on Nov 12, 2009
  • 75 Answers
SOURCE: Benq MP 721 projector purple colour when it projects.
You are missing one of your primary colors and this is usually to a faulty pin where you are connecting your vga cable to. It could be either the pin on vga port of your projector or it could be the vga cable itself. Please look at the pins especially if you are using one cable to try with all the compputer.
Posted on Jun 05, 2010
SOURCE: benq w600+ projector the menue will
First check that your computer and HDMI cable are 3D capable, if it still does not work contact Benq support.
Posted on Mar 04, 2011
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
Screeching sound from Bose 901 Equalizer
Check the treble on the EQ, is it possible to take a pic of the equalizer?
May 27, 2013 | Audio Players & Recorders
My benq MP 512 shuts down after a few minutes of use. when it shuts down all 3 light indicators are off, fan also goes off.
DONT WORRY THIS IS A REGULAR PROBLAM OF BENQ ,DELL,INFOCUS PROJECTORS UR MAIN POWER SENDER IC IS DAMEGED THROUGH UR PROJECTOR AND BUY EPSON,HITACHI,SANYO PROJECTORS
Mar 12, 2012 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
Bose free space 51 speaker pair. 1 speaker stopped working. I disconnected non working speaker and hooked up at the working speaker wire and it still didn't work. don't know how to take it apart to...
In my case the speaker only played the higher frequencies but not the low mid range to base. Most likely your speaker is "blown". Outdoor use is hard on electrical components. The fix is easy. The free space 51 speaker is identical in size to the standard Bose 901 4 1/2" speaker. You can buy a Bose or a good quality knock off (either way they will need to be broken in before yielding the best sound). It is not clear to me whether the original Bose uses a special moisture resistant cone. I treated my replacement with a light coating of silicone spray (for upholstery) carefully protecting the foam surround and cap at the center.
Just unscrew the three screws holding in the plastic grill in front of the speaker (using a nut driver or socket wrench). The speaker will drop out. Be careful with the foam wrap around the wire as it tends to be fragile and greasy. Solder in the new speaker making sure you get the polarity right (although for outside use this is probably irrelevant). I would test the speaker in place before soldering just to make sure. Reassemble and break in the speaker. Again I don\'t know know well the replacement will weather the elements. Keep your finger crossed.
Jul 23, 2011 | Bose Free Space 51 Main / Stereo Speaker
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
How do I get sound from bose cinemate while watching Bluray with?
You are right I checked the Manual online and there is no Optical in. The other tech was right in suggesting that, Cause it would be the next best thing to HDMI. It only has 1 Analog Audio in, So what I would Recommend is Plugging in all of your Devices to your TV and then 1 Audio cable from your TV to The Bose input. Although this will NOT transfer Digital Audio to Analog Audio. This means if you are going in HDMI then the Audio would most likely NOT transfer to the Bose. In this case you would have to hook up a set of Audio cables (Red and White) From the Blu-Ray to the Bose along with the HDMI. This will leave you with only Audio from the Blu-ray through the Bose. To go a step further you can purchase an Audio Splitter (or Video) then plug your Devices into the Splitter and then 1 cable out to the Bose and just Switch the Input along with the TV. Good Luck!
Apr 29, 2009 | Bose Cinemate Digital Home Theater System...
BenQ MS510 3D Projector Logo
56 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
