Question about Zenith Z50PX2D 50 in. Plasma HDTV
DID KNOT HEAR POP JEST WENT BLACK CAN HEAR AUDIO
Long black screen during cold boot
Check your RAM and the ..... ummm maybe jest ram do you hear beep sound
Nov 11, 2012 | Lenovo Essential G570 43348pu 15. Led...
Heard a pop and picture went black ,no audio .lamp has never been replaced.
You need a new picture tube. The same thing happened to my tv. My audio went out also but for some reason when the tube was replacd it fixed the problem. The tubs are about 200.00
Nov 13, 2010 | Sony KDF-E55A20 55 in. LCD Television
I have a Sony 50" WEGA rear projection tv. Last night it made a popping sound and then the screen went black. I could still hear audio at that time. I turned the tv off and now there is a blinking red...
It sounds lamp in tv got broken as you heard pop sound of it, replace lamp in tv to fix the issue.
Blinking light would be Lamp light at tv front that shows lamp is dead.
Lamp replacement procedure is easy and mentioned in tv user manual.
Thanks.
Sep 13, 2010 | Televison & Video
I have a Sony E55A20 tv. It made a pop noise and went black. No audio either. Power light is still on. Does the audio go out if the projection lamp goes out?
Yes. If you hear a pop, the lamp probably exploded. You should pull it out and have a look. You user manual has some clear directions on the exact method of doing this. Don't be afraid of the instructions provided... the manufacture must "scare" you to cover their own ****. It's fairly easy, but you may need an allen key for this model. I hope this was helpful, best wishes.
Apr 17, 2010 | Sony KDF-E55A20 55 in. LCD Television
Runing jest back spekers
Yes, you will need to disconnect wires to the front speakers
Sep 05, 2009 | Phase Linear UPA424CS Car Audio Amplifier
TV pop and screen is black but I still have sound.
check your vedio transistor colector voltage is above 60 v
Apr 11, 2009 | RCA Televison & Video
Weird Rapid Metallic Popping Sound
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Sep 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Zenith Z50PX2D 50 in. Plasma HDTV Logo
59 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
