Question about Roper RGX5635E Dryer
We purchased a Roper washer and dryer in 1998, Its been the best, never a problem. However it has started making a high pitch squeek that has gotten really loud. The drum still turns Maybe somethings
In the manual it says to take out the 2 screws inside the lint screen flap and pop top up. Not happening!
  • 61 Answers
YOU HAVE TO OIL THE ROLLER AND IDLER PULLY EVRY 5 YEARS IF YOU HAD NOT HAD IT DONE YOU MAIGTH HAVE RUING THE ROLERS LOOK FOR VIDEOS ON YOU TUBE HOW TO OPEN A WHIRPOOL DRYER SAME BRAND.
Posted on Feb 22, 2012
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
HIGH PITCH SQUEAKING NOISE WHILE DRYER IS RUNNING.
check heatmans blog http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking also make sure the dryer belt is aligned and has tension , often an oversized load will cause belt squeek
Jun 05, 2011 | Fisher and Paykel Dryers
I have a GE Profile 6 cycle dryer. It is making a high pitch squeeking noise.
Replace the rear drum bearing. You do not list a model number, so can not give much more info than that.
Mar 06, 2011 | Dryers
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
Dryer modle #lde9334ace making noise
More than likely it is the belt. A simple fix is to spray some belt dressing on the belt. However, changing the belt would be the best solution. Good luck.
May 18, 2009 | Dryers
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
High pitch whine/sqeak
Suggestion: Try some anti-squeek on the belt, or some soap. Plug off the wall first.
Sep 09, 2007 | Magic Chef CAV4000AWW Top Load Washer
Dryers Logo
236 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
