Question about Dishwashers
Hobart Kitchen Aid dishwasher KDS-58. This washer is a champ. Recently it started leaking water from the lower left corner of the door, while the washer is in the wash mode. I replaced the lower seal, below the door, the seal is installed correctly. Not sure what to do next?
  • icaughtfire0 Apr 25, 2009
    i don't know if you'll get this since it was posted a while ago...I just recently got the same dishwasher and i can't not find the right sink adapter anywhere? any
  • 290 Answers
SOURCE: kitchen aid dishwasher door
Use white silicone. It doesn't show up against the tub and it is easy to clean off if you ever have to replace the seal. That is what Whirlpool sends to glue them in place. You can get a small tube at any hardware store or wal-mart.
Posted on Nov 30, 2007
  • 489 Answers
SOURCE: Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
Posted on Jun 08, 2008
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
SOURCE: Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Posted on Nov 16, 2008
  • 41 Answers
SOURCE: need users manual
parts are longer avaible it is obsalete
Posted on Dec 09, 2008
How do I fix this. Kitchen aid dish washer?
It appears to be the door switch sensor.
I suggest replacing it.
Mar 20, 2016 | KitchenAid Kitchen Aid - KUDE40FXBT...
Where is filler sylonoid for hobart lx30h dish washer
The fill solenoid is behind the lower panel, attached to the left side of the booster tank. There is a screen in the end of the fill hose that may be clogged. You require 20 psi flow rate to run the machine properly.
Pull the top tray out, place a magnet on the door switch, with the door closed and monitor the 3 led lights on the control board while its filling. All 3 should light up. Use caution around the high voltages present on the relay board and the booster contactor.
The probes in the right rear corner of the tank send the water level signals to the control board. The tips must be clean of scale or debris that may signal that water is present, when it is not.
May 28, 2014 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Leaks in lhe left lower corner of door
Jan 07, 2011 | Kenmore Dishwashers
Leaking water
Check and replace the seals if need.
Jan 06, 2010 | Dishwashers
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Pin hole leak in metal under dishwasher
difficult to weld stainloess steel. another way is to drill out the hole slightly and fit a small nut and bolt with fibre washers
Apr 12, 2007 | KitchenAid 24 in. KUDI02CR Built-in...
Dishwashers Logo
135 people viewed this question
Top Dishwashers Experts
