Question about Dell Computers & Internet
Computer does not connect automactic when wireless
  • 2,632 Answers
Welcome to Fixya. Can you please provide the OS of your computer so that we can provide you a step by step guide on how to fix your issue
Thanks
Posted on Feb 21, 2012
Irocz z28 1987 700r auto will not shift automactically but i have reverse 1 2 but no drive or over drive
The 700R4 had its problems, they seldom lasted more than 100,000 miles without a rebuild. The ****** only has computer controlled torque converter lock up and OD control. So the problem you are having are likely mehnaical. The computer in this year is called the ECM not PCM.
Oct 04, 2012 | Cars & Trucks
START UP REPAIR SCAN CANNOT REPAIR COMPUTER AUTOMACTICALLY
It will not scan because the area/partition/segment for which the software was put was tampered with. You might have to get an external disk drive and use that instead fro the scan process.
Dec 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
After installation of Biostar G41-M7 mother board, the system automactically shuts off after powering on, what can I do to resolve this problem?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 05, 2010 | Biostar G41M7 Motherboard Intel Pentium...
My 1991 ford Bronco will not automactically kick down I have manually shift down
being a 91 i am guessing its a EAOD transmission, it is also computer controlled. it could be the adjustment on for the Valve body cable aka kickdown cable needs adjusted or could also be a problem with the computer.
May 18, 2010 | 1991 Ford Bronco
Im missing the driver for the cd rom
Hey all you need to uninstall the corrpected driver or the driver that is curently instlled and then restart the computer, it will automactically install the driver
Oct 12, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
Problems loading
click on start, click on run, type in msconfig, click on startup and look for the file m3plugin and uncheck, click on apply and restart your computer.
Oct 24, 2008 | Intel Motherboard
Help
well ok 1 you must connect the cam with a USB cable to your pc windows xp wil install it automactic!!!
Feb 07, 2008 | Vivitar ViviCam 3750 Digital Camera
Print spooler
Click on Start Click on run Make sure the run line is clear Type services.msc You will see a list of services Make sure all items below are set to automactic To make the changes double click on each item line change to automactic if diabled. Then click apply when you are done. Printer Spooler LexBce Server Remote Procedure CallRPC) Restart the computer Hope This helps
Sep 17, 2007 | Microsoft Windows XP Professional With...
Printer Spooler
Exactly what it says...(smile) Click on start click on run Type services.msc A box will open up Make sure all items below are set to automactic To make the changes double click on each item change to automactic if diabled. Then click apply when you are done. Restart the compputer and try testing your printer again. Printer Spooler LexBce Server Remote Procedure CallRPC) Hope this solves your problem
Sep 16, 2007 | Epson Stylus Photo R220 InkJet Printer
Canon MP810
Try this Click on start click on run type services.msc a box will open up with listings Check each of the following to see if they are running LexBce Server- should be set to Automactic Print Spooler- Should be set to Automactic Remote Procedure Call(RPC)- Set to Automactic If any of these items are different- change them by double clicking on the line. A box will open up make changes then click apply. Shut down and restart your computer. Hope this helps you
Sep 15, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Computers & Internet Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
