Question about Mitsubishi Televison & Video
WD-65737 mistubishi DLP television has what looks like black hills along the bottom, screen is darker than normal even moving brightness to high, and has been shutting itself off on occasion with led
My television was manafactured in Decemeber of 2009, I have had the television since February of 2010. Just in the last week we have been having problems with the television set the first noticed problem is the tv shutting itself off on a few occasions I would leave the room to go to the bathroom during a commercial to come back and the tv be off with an orange light present on the front. The next issue that just began last night was a large and varying in size black stripe along the bottom. This black stripe looks like hills goes up about 5 inches on left side, down to about 2 inches varied in the middle , and back to 5 inches on the right side of the tv. I was wondering what this problem could be for have not seen ANY discussion on it.
5 Suggested Answers
freetek
  • 5568 Answers
SOURCE: 46 sam dlp problem
This is pure conjecture but I think the cooling fan has failed or is running slow.
Check to see if it can still be heard.
This system seems to be a bit weak on reliability.
Posted on Mar 30, 2008
  • 1779 Answers
SOURCE: I have a 30" Phillips
First- Do you have a cable box ( with a volume menu in it)?
If you do make sure the volume on the box is at least 3/4 full, no lower. Then re adjust the volume on the tv to a normal level and let me know
Posted on Apr 04, 2008
  • 10 Answers
SOURCE: Sony KP%&HW40 with varying background tinting
YOU HAVE 6 ADJUSTMENT BEHIDE THE SPEAKER SCREEN. THERE ARE TWO SCREWS YOU NEED TO REMOVE. ADJUST JUST THE MIDDLE BOTTOM SLOWLY. IT SHOULD CLEAR YOUR PICTURE. IF IT DOES NOT WORK IT MAYBE YOUR GREEN CRT. THIS TV IS GARBAGE. IM TRYING TO GET 100 PEOPLE CALL SONY APRIL 17,2008 AND GTHEN SEND TGHEM A LETTER AND AFTER CONTACT YOU LOCAL MEDIA FOR THIS DEFECT. SONY HAS TO PAY YOU BACK OR REPLACE THIS TV.
Posted on Apr 05, 2008
johnychel
  • 796 Answers
Shut down with increased brightness: most likely cause is loose wire on pin # 2 on P406 (ABL) located at bottom left of power supply board. Press wire into plug portion for tighter connection.
Posted on Jun 17, 2008
I have a mistubishi tv model wd-65737 with bad picture. I replaced the video chip and color wheel but that didn't work....is it possibly that dmd board?..thx
Hi, can you tell me what you see on the screen? It could be a bad cable. Are you using an HDMI cable or the color cables (RCA cables)?
Jul 28, 2016 | Mitsubishi WD65737 65" DLP TV
Why does my Mitsubishi WD-65737 TV go black for 4 or 5 seconds then picture comes on again with the top left corner says "Cable Box".
Replace service cords, as they might be getting worn and loose. It does sound like that to me. Bad coaxial cables
Apr 10, 2015 | Mitsubishi WD-65737 65"" rear projection...
Mitsubishi WD 65737 black screen
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
Dec 22, 2017 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi wd-65737 DLP - Black film on the bottom of screen
Kind of like a black strip left to right that is not perfectly level?
What kind of table or shelf etc is it sitting on?
These sets (happened to me when first saw them) have to have the base completly on something wide enough to support the whole pedestal base--
You can try to gently twist the cabinet a bit to see if the band moves--the other possible things are there is from the front(some work to get at) mechanical adjustments (doubt it is your problem)
The worst possible reason is the Optical engine is burnt from heat from the lamp----want to rule the other possible things out first.
Apr 10, 2012 | Televison & Video
The picture on my mitsubishi wd-60c9 is darker then normal and adjusting the brightness settings does not help how do i fix this problem
Brian, See my answer to Brenda, the question before yours. My TV did the exact same thing in September. Time for a new bulb, before it all goes black in a few day!! Better hurry, too!! EBay or 'ShopJimmy" will fix you up with a new bulb. "Bulb only" is cheaper and a few muniutes to swap over. Entire bulb assembly costs a few dollars more, but then all you do is slide old one out and new unit in.
Nov 02, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Open Questions:
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
