Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher Whirlpool quiet partner 2 will not drain
When the dishwasher is done and the drying cycle is over there is water in the bottom. We hit the cancel and drain button and that gets rid of some of the water. we usually need to hit this botton 3 times.
Check your drainage hose going to the kitchen sink. It should be routed up to an air gap on kitchen sink, or ran to the highest point as possible under the kitchen sink counter and then slope down into the disposer or branch wye tailpiece on your drainage piping depending on what your drainage configuration is. Not going up to the highest point, or an air gap, before draining into your drainage piping allows the water inside the dishwasher hose to drain back into the unit.
Posted on Feb 22, 2012
SOURCE: Whirlpool Quiet Partner II dishwasher
Don't have a Sani-rinse button. Held down the Air Dry (control lock) button for a while and the lock light went out.
Posted on Oct 31, 2008
Thank you so much!!! heated dry & hi temp buttons worked!!
Posted on Feb 13, 2008
SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Posted on Sep 09, 2008
SOURCE: whirlpool dishwasher # quiet partner II
THIS WORKED FOR ME!
push" heated dry",then "normal" then" heated dry" then "normal"--it worked like a charm..did the happy dance,washed dishes and saved $130.00!!
Posted on Jan 26, 2009
  • 552 Answers
SOURCE: whirpool dishwasher quiet partner 2
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
We have a Whirlpool Gold Quiet Partner GU980SCGZ0 model. When rinse cycle is over the water only trickles out when draining. We checked the drain and it is not plugged. Water remains sitting in bottom of...
I took the check valve assembly off the bottom of the pump assembly and there was a big chunk of string balled up in the line which created a plug against the screen when trying to drain.Works great now!
Feb 15, 2010 | Whirlpool Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Whirkpool quiet partner 3 dishwasher status stuck on clean. If I press cancel it goes into a 2 minute drain cycle, but there is no water in it. It will no reset or start....just blinks clean.
if you have a heated dry option and normal wash option push those buttons back and forth three times all the lights will come on reseting the board..
push cans. and your done
if this happens again that means you have a bad heater or bad board
Aug 21, 2009 | Whirlpool Dishwashers
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
831 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
