Question about Refrigerators
How to install Part No. 216280500 in Model No. 253.9165510 Kenmore deep freeze
Replace temperature control ?
gpgab97
  • 77 Answers
SOURCE: The refrigerator is freezing, I
It may need a new computer board, a buddy of mine makes a killing fixing these new "elite" refrigerators because of this. Same problem with the GE's
Posted on Apr 30, 2009
mgprice
  • 744 Answers
SOURCE: I have kenmore refrigerator model- 253 67172504. water inside
Hi. The problem here is going to be with the defrost drain. Follow tthis link to my tips for full details on fixing this problem. Mike
http://www.fixya.com/support/r3557045-how_to_clear_a_blockage_in_the_defrost_d
Posted on Dec 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore refrigerator Model 253-68232800 will not
Look for a failed compressor condenser fan under the ice box, check the relay, clean the junk from under the ice box, if you think it is the control and the control you have is the standard 2 wire mercury type you may jump it out and see if the ice box freezes.
Posted on Jan 18, 2010
  • 1891 Answers
SOURCE: My Kenmore Top Mount Refrigerator Model 253 is not
clean the coils and make sure the fan's ( both) are working .. mm
Posted on Jul 03, 2010
  • 1156 Answers
SOURCE: kenmore 253. 9287413 Can't get
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
I hope this will help in solving the problem......
Posted on May 10, 2011
Kenmore frost free freezer model253.24452100 turns on but does not freeze. The compressor kicks over then stops. What might it be?
Is the compressor still receiving 120VAC when it kicks off? Kenmore Freezer Temperature Control Thermostat 216788000
If not, replace the cold control. If yes, install a URCO410 hard start kit and listen to it purr... Relay overload capacitor URCO410
Mar 22, 2016 | Kenmore Freezers
My kenmore coldspot mode 106.53394300 is freezing items in the fridge
If further adjustments cannot be made to the thermostat, the next step would be to replace the thermostat or if so equipped, the temperature thermistor.
Jan 30, 2015 | Kenmore Refrigerators
The temperature in refrigerator is coler than setting on the display why?
Before I begin is the model number=> GI5FVAXVL correct? If not I will need the correct model number to proceed. Thanks, John Tripp Appliance 911
Jan 29, 2014 | Whirlpool GI5FVAXVL (249 cu ft) Bottom...
Kenmore 50522 refrigerator freezing everything
What is the model number listed in the refrigerator section?
Oct 15, 2012 | Kenmore 50522 / 50524 Side by Side...
I have Kenmore Elite 59673503201 freezer fan went out replace then it started freezing at the bottom of the refrigerator put in new vent control at the top of refrigerator still doing the same thing
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 17, 2012 | Kenmore Refrigerators
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i...
This is the coomon error of the deep freeze . I you can not access deep freeze then download deep unfreezer from http://www.brothersoft.com/d.php?soft_id=171878&url=http%3A%2F%2Fusfiles.brothersoft.com%2Futilities%2Fmiscellaneous%2Funfreeze_quicksetup.exe
Then disable deep freeze with out password after that use the same istaller to unistall the deep freeze which you have used to install .
Nov 02, 2009 | Computers & Internet
Kenmore model 596.52673202 refrigerator not cooling or freezing
the defrost should be controlled by a timer every 10 hrs or so,it is usually in the bottom of the fridge by the compressor,it has a small motor that turns the timer,they burn out
Jul 21, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side coldspot, model 5687
I'm not trying to be a smart ***,but a lower temperature setting would make it colder.Try using a higher temperature setting.If this was just a poor choice of words you may need to replace your thermostat.
Jun 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Deep freeze
hi.. ! i am working in internet cafe , from yestarday hotmail is not working they say you have to install new version of windows massenger. i can install the new version of windows live .but i have deep freeze in my every computer.but i can't see the deep freze icone in my textbar its show but when i go to put mouce corser its desapiar i wnat to disable the depfreze .pliz help me any one.. what sholud i do ..? and when i try to reinstall the deep freez then computer says " disable first the allraday insatall deep frezz , pliz help me. thanx.
Mar 03, 2008 | Computers & Internet
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
