Question about Bosch Nexxt 300 Series WFMC2201UC
Bosch 300 series washer// led code E04
I can't unlock the dooir. I have a led E04 msg
  • 2 more comments
  • cynhenderson Dec 18, 2008
    I have the same problem, and once I switched it off it wouldn't turn back on. After a few days, I would plug it back in and the control came back on.
  • Anonymous Feb 01, 2009
    SAME PROBLEM
  • Anonymous Apr 29, 2009
    will not drain, spin or unlock
  • Anonymous Mar 25, 2014
    Though I use the correct unlock code to open the phone, it doesn't swich on
    Problem Solver:
  • 5 Answers
Remove the access panel at the front botton right corner. There is a manual release button you can pull.
Posted on Mar 02, 2009
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
What is error code E04 on hoover washer
E:04" on the washing machine. Check to ensure there is no water in the tub. This is a common error often associated with too many suds blocking the pump. It is caused by using the wrong laundry detergent which is not designed for high-efficiency washers. You can adjust your use of detergent and reset the machine to eliminate the error code.
Read more : http://www.ehow.com/how_10038363_reset-bosch-washing-machine-error-e04.html How to Reset Bosch Washing Machine With Error 04 eHow
Jun 21, 2015 | Hoover Washing Machines
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
Sep 10, 2014 | Washing Machines
E04 error code, washer wont drain, water left in tub on a Bosch Nexxt 300 series
http://applianceguru.com/attachment.php?id=2463
Make sure you click helped, if helped that is.
Apr 12, 2013 | Bosch Washing Machines
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch washing machine E04 - won't drain or unlock
if it's like mine.. there is a small round cover w/ a small hole in it. rotate it to the left until it pops open.
May 22, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch 500 Washer - Can't Open the Filter Door
I did it! The trick was to push a small nail into the hole and push in on the filter door while rotating the door...all at the same time. The original problem was the water not draining and the washer displaying code E04. Just like a previous solution stated, there was one knee high sock in the drainage pipe.
Nov 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
I have a bosch wfmc 2100 washer that doesn't drain
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Jan 01, 2008 | Bosch WFMC 2100 Front Load Washer
Bosch Nexxt 300 Series WFMC2201UC Logo
1,036 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
