Canon copier imagepree C1 Throwing E060 codes any suggestions
Checked charge unit hp sensor...
I WOULD completely UNINSTALL PROGRAM...delete "PROGRAM FILE" ASSOCIATED WITH SAME, IN "PROGRAM FILES"..."EMPTY TRASHCAN"...RESTART" puter...DEFRAG...RESTART puter...RE-INSTALL program...Simply put, START FROM SCRATCH !!!...OPEN "SERVICES", in "CONTROL PANEL"...RESTART "WINDOWS INSTALLER" AND BOTH "RPC" services...BEFORE RE-INSTALLING THIS PROGRAM...Then, after re-install...RESTART AGAIN...See if it now works...While RE-installing, fill-in REGISTRATION info also...Should fix your problem...Let me know if this works, k?
Posted on Feb 21, 2012
Canon laser shot lbp9100 CDN error code 78-0001
E078 - Error in detecting HP of ITB cleaner (Error in failure of detecting HP (pressure) of cleaner unit of transfer belt)
0001 - The HP sensor does not go on within 5 sec after the start of a HP search.
Jan 03, 2017 | Canon Office Equipment & Supplies
Code c1-14
check the charge drum assy. above the drum.
Aug 21, 2014 | Sharp Office Equipment & Supplies
Error canon C1 CODIGO E000070-0201
ITB HP detection error,Clean the HP detection seal,clean or replace the HP sensor
Jan 12, 2013 | Canon imageRunner C3100N Copier
Error code display 00007 in ir 3300 canon copier since i have checked fuser unit thoroughly and changed the fuser flim roll of fixing unit still then the error code display manually and after switch ON...
as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
Sep 15, 2011 | Canon imageRUNNER C3200 Copier
Error e020 0180 on canon imagepress c1 please give me a reply
getfile.asp?rid=1258 November 02, 2010 getfile.asp?rid=3215 Product : imagePRESS C1 / C1+ Title : E020 with Multiple Sub Codes for all Colors Problem :
Solution :
Check for a pinched or damaged wire harness from PS3 Patch sensor #2 from connector J426 back to the Side Driver p.c.b at connector J3415 and at PS7 ATR sensor from connector J209 back to the Rear Driver p.c.b. connector J3802.
getfile.asp?rid=33199
getfile.asp?rid=33201 Canon USA, Inc. Systems & Technical Support Division
Dec 19, 2010 | Canon CLC 1120 Color Copier
Error E000020-03a2 canon c6800
pls check the cyan deverloper if it irc6800.drum unit if it is irc3200
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
Canon IR600-550-60. Error code E001.
550 just gave an error code E060, what do I do?
Nov 09, 2009 | Canon imageRUNNER 600 Printer
I have error code E000732-0001 on Canon imagepress C1
Error :
E732 code
Workaround :
E732 code is a Reader communication error.
If the Reader is disconnected from the Printer a E732 code will result. Once the Reader is disconnected the logic on the MAIN-Controller is changed to a "0". The copier is now set up to be a Printer only, and will not recognize the Reader.
To correct this, you must enter service mode, COPIER>OPTION>BODY>W/SCNR and set that to "1". Then you must turn the copier off, then on.
To enter service mode: press "Additional Functions" then "2" and "8" together, then "Additional Functions".
Which User Guide? Reference, Easy Operation Guide, Printing Guide, Mailbox Guide, Sending Guide etc....
Sep 09, 2009 | Canon imageRUNNER C3200 Copier
Error code 840-002 in clc 5100 color laser printer when i take copies from paper deck R1
E840 codes reference problems with the Fuser Unit or Fuser Unit Drive.
Does paper deck R1 have heavier stock loaded in it? Found reference for subcode 0002 stating failure of HP sensors 1 & 2 in the Fuser Unit.
(external heat roller home position sensors) Part number FH7-7306-000 same for both sensors.
Aug 15, 2009 | Canon Office Equipment & Supplies
Canon ir 3100 cn error code e000020-0081
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
109 people viewed this question
jasbo
jasbo
