Question about Ricoh Aficio SP C410DN Laser Printer
Printing pink line down paper ricoh
Pink line down one side of paper when printing
Bubbabear64
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
  • 58 Answers
SOURCE: lines down left side of paper
replace the Black PCU
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Thin lines along left side of Ricoh CL2000N laser printer
This is almost certainly the PCU. There are two. One for Black. One for Color. Print a B/W page and see if there are lines. Print a color test page and see if there are lines. This happens a lot to these printers.
To verify, carefully remove the suspect PCU and look at the bottom of it (the shiny roller) Be careful not to spill toner !! You will see the lines on the PCU itself. Replace the bad PCU. If it is the color one, and you are low on toner, you may be better off replacing the printer due to cost.
Posted on Aug 20, 2009
  • 8 Answers
SOURCE: A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Posted on Mar 31, 2010
newport74
  • 58 Answers
SOURCE: My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Posted on Apr 06, 2010
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
Pink lines when I print on proper Canon photo paper
i'd say your print engine is quite out of sync...you had this canon for a while?
Mar 18, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Black spots on paper - Ricoh Aficio MP2000
If it uses a cartridge, check for leaks. If a leak is found, there may be toner scattered inside the copier
Oct 11, 2012 | Ricoh Aficio MP 2000 Black and White...
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Hi Ricoh 1232 copier and printer. Both copies and prints are produced as if the paper feed was slightly delayed and the print moves over about an inch: effect is you have a large margin on the left side...
Is the paper in the tray landscape-oriented or portrait-oriented? If it's landscape-oriented (short edge is fed first) then you might just need to realign the paper fences. There is a screw holding down the gear in between them -- if you remove that screw you can move the fences so that they're both lined up correctly. (Push them both in all the way or out all the way, then reinsert the gear and screw it back down.)
If the paper is portrait-oriented, it may be an adjustment that will have to be made by a Ricoh service technician. It is a simple adjustment to make, and should only take a minute or two if you can have a tech look at it.
Apr 11, 2011 | Ricoh Aficio 1232C Color Copier
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Black streaks
HI there it would need a PCU (Photo Condustor Unit) or drum unit which ever you prefer.
Thanks J
Dec 12, 2007 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio  SP C410DN Laser Printer Logo
109 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
