Related Tags:
This problem should be removed because:
Problem with Danby DDW1805W Designer Series Free-Standing Dishwasher
broken casters (wheels)
Two of the four casters (wheels) that make the dishwasher mobil have broken off at the back of the dishwasher. It looks very complex to fix them. How do we do this. The wheels are plastic and they snapped off with out any force. I just moved the dishwasher in a straight motion and the dishwasher was not over loaded. I would prefer to replace all four casters with non-plastic ones to ensure better durability.
Solutions (3)
Best Solution
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
FAST and EASY SOLUTION that WORKS!
DO NOT TAKE THE DISHWASHER APART!!!!!
but Turn it UPSIDE DOWN
There should be a Drain Plug (if you got water there)
If a wheel breaks
1) use pliers to pull whats left of the plastic wheel off the metal fixed shaft
2) buy replacement wheel from Home Depot
Shepherd 2 in. Twin-Wheel Stem Casters 2 Pack
http://www.homedepot.com/h_d1/N-5yc1v/R-100082918/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
3) use pliers one again to pull the shaft of out the Home Depot plastic wheel (takes some works)
4) attached the new plastic wheel to the Dishwasher's metal wheel shaft
(if the wheel is loose, add some tape to the metal shaft to make it
tighter fix)
5) your done, simple as ABC123
6) clean your dishes and smile :-)
In case you haven't fixed this yet, I had the same problem and called Danby. They shipped out a new caster right away for no charge, and it's been fine ever since (2+ years now). So try giving them a call.
GE dishwasher nautilus - bottom tray caster wheels...
Hi, Our problem is the plastic caster wheels on the lower level of the GE dishwasher. We replaced them 4 months ago but they are so poorly...
Wheels fall off GE dishwasher
Have the same problem with our GE Monogram Dishwasher. The wheels fall off. A while back we bought a service contract from GE for this...
The inside top of dishwasher
The inside top of dishwasher has a part that spins to spray water but keeps falling off ? Looks like it just snaps back in place, but falls...
need 2 casters
I bought the Frigidaire portable approx 4 years ago and have moved in the meantime. Unfortunately the 2 back casters broke as we were moving...
Add Your Solution
Water won't load into dishwasher
I accidentally put in dish soap. oops!!! Now the dishwasher won't load with water. What can I do?
My timer stops...
I turn the timer to wash and it sounds like the timer is catching up to where I want to start the cycle and the timer...
Hi, I have a Danby 1805 dishwasher. When I start...
I can't seem to find any leaks on the hoses leading to the tank. The clamps seem to be alright. I can't...
The dishwasher is receiving water and power but
The dishwasher is receiving water and power but won't start. The red light for the rinse aid is on. Do I need to...
I have a danby allfridge & i'am finding
I have a danby allfridge & i'am finding water at the bottom of the crisper.
See all Danby DDW1805W Designer Series Free-Standing Problems
Fix-O-Meter
264
264 people viewed this problem
- 4 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Danby Dishwasher Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
